1 - 7 of 7 Posts
I've a few error codes that have just made an appearance, last week Check engine notification with orange CEL and the loss of DNA. Reset the codes using the engine on/off technique but it happened again today.
Below is a copy of the codes from 'CarScanner' iOS app, the obvious thing to do is to get this checked out however I'm interested if anyone has seen these codes before or could recommend another scan app for iPhone (I can't get Multieuscan to work with the Bluetooth scanner).
I drive a 2017 Giulia QF, the car wasn't under any aggressive driving before the codes came up, if anything more like start stop traffic.
I'd love to know if anyone has had a similar experience.
Thanks.
============1==============
P026A
Raw code: 026A
ECU: 10[Archive (inactive)]
Status: Permanent
OBDII: Intercooler - efficiency below threshold
============2==============
U0001
Raw code: C001
ECU: 18
Status: Confirmed
OBDII: Controller area network (CAN) data bus, high speed bus
============3==============
U0401
Raw code: C401
ECU: 18
Status: Confirmed
OBDII: Invalid data received - engine control module (ECM)
============4==============
U0121
Raw code: C121
ECU: 17
Status: Confirmed
OBDII: Data bus, anti-lock brake system (ABS) control module - no communication
============5==============
U0121
Raw code: C121
ECU: 10
Status: Confirmed
============6==============
P026A
Raw code: 026A
ECU: 10
Status: Confirmed
I would check the coolant level in the intercooler cooling system... I would guess it's either low or you have an issue with the water pump for that system.... the other codes I would ignore for now
wow I just checked and the front was almost empty and the rear had dropped in the last month.
would you think it’s better to clear the code and the CEL light or leave it be to see if topping up the tanks with coolant resolves the error?
At this point I would drop the aero cover and look for the leaks. Main Radiators are a problem if you haven't replaced your's yet. I would look at the intercoolers to make sure a rock did puncture one and finally not sure if the turbos are water cooled but I would check those lines as well.
I would clear the codes, top off the cooling systems then do what @The_Dude said ..you have a leak somewhere, you just need to find it... it's likely a small leak, so you may need to pressure test the system to locate it , but coolant leaves a trail where its leaking so look for a sign of orange looking crust around the radiator edges and on the belly pans
I would also add it will also leave dry white patches/dots too when it dries.
1 - 7 of 7 Posts
