The trunk release is on the inside of the trunk lid just above the latch. It's helps to see it if you can turn your head 180 degrees. It's a white slide lever inside a hole. It probably glows in the dark per Federal regs.There are two buttons. The little one locks/unlocks while the larger one releases.
Has anyone found the interior trunk release button? My salesperson didn't know there was one.
Not the one inside the trunk, billeee. Rather, the one inside the passenger cabin.The trunk release is on the inside of the trunk lid just above the latch. It's helps to see it if you can turn your head 180 degrees. It's a white slide lever inside a hole. It probably glows in the dark per Federal regs.
Yes, it's down by the hood release. Very small square button.There are two buttons. The little one locks/unlocks while the larger one releases.
Yup. Easier to spot with the light-color interior. And a bit of a reach from the driver seat.Yes, it's down by the hood release. Very small square button.
