1 - 9 of 9 Posts
When the car is warmed up and it's being driven under normal driving conditions. Should it be sitting at the middle? Mine is a bar higher than the middle. I would assume a software update is out there for this?
The ECU update will re-calibrate your Oil Temp gauge to read exactly in the middle among other changes to the engine management software. Currently your dealer will not perform the ECU update unless your car is exhibiting issues with stalling, misfires, etc as mandated by AR and you as the customer comes in to complain about it. Your dealer will then issue a ticket and AR will authorize the update.
My car stalled right after I paid the toll at the bridge. It displayed a fault, (forgot which one) but it went into neutral. Would the ECU store that fault even if it was a week old?
Yes, that's a clear sign of an old software version, new version shows 1 bar less at normal operating conditions.
I figured that was the case, is that update for the oil temperature solely for the oil or does it over engine management such as controlling any misfiring?
Yes, the update should correct a myriad of other gremlins including stalling after fillup and misfires. ECU warning should be stored ind finitely until manually reset through an ODB2 device.
The error displayed would have said "Fault detected re-start required" The fault code will be stored. Take your car in for service ASAP.
excellent thank you, it appears the dealer where I had purchased it told me they updated it but I do not think that was the case
1 - 9 of 9 Posts
