1 - 18 of 18 Posts
2017 Alfa Romeo Giulia Super 2.2 150 ATX RWD, 1992 Pontiac Firebird 3.1 V6
How’s the handling compared to Pirellis?
You do realize 245/35 R19 is the wrong dimension? 225/40 in front, 255/35 in the rear would be correct.
Tipo 33 Stradale 1/18 scale
i thought all Michelin had that textured finish around the word Michelin and Pilot Sport 4/s look more like this
https://www.tractionnews.com/wp-content/uploads/2017/10/New_Mustang_GT_gets_Michelin_Pilot_Sport_4_S_tires-1000x600.jpg
2020 Alfa Romeo Giula Ti-Sport Carbon AWD
that does look like mounted inside out @J4tuna
Reactions: Papa Gallo
if you are within 3% of original size, you are within tolerance so it's fine and wouldn't call it wrong dimension.
including myself, there are others running 245/40 or 235/40 size which is also within 3%.
Reactions: Richo8657
245/35 is what the QV has in front on 8.5" wide wheels, and it's completely fine on the 8" wide wheel.
Mounting them wrong is no good though, who in the hell did that? Run from that installer, fast. (after they fix it first)
Theres staggered 5 holes and square ones i believe.
Squares are 8" all around.
You can put the 245 on an 8" wheel although its maxed out and treadwidth is .6" wider that the wheel so you'll get more squishy handling (more deflection) and slower acceleration (due to upping the overall diameter).
Mike
Discussion Starter #10
Handled great.
Had at 115 and no wheel shake.
Rear wheels dont break loose in turns.
Hoping for better tread life w more of a flat foot print.
Inner tread went fast on the Pirellis
Handled great.
Make sure you take them back to get mounted correctly.
Discussion Starter #16
Unfortunately it was the largest tire distributor in Arizona that mounted my tires. I suppose they put an amateur on my car and that's not a good thing. I did call and they are changing it for me today. Thank you again noticing this.
1 - 18 of 18 Posts
