1 - 7 of 7 Posts
Hello Everyone,
Just purchased my Giulia last week and I love it. I can't wait to go past the 1000 miles so I can drive it more like I want to. However, I do have two question hoping someone can help.
I just got my car back from the dealer for an update and there are two things they mentioned that trouble me a bit.
First, I noticed that my back up cam stays on for a good 15 seconds after I either park or set it to drive. Dealer says this is normal and preserves the life of the camera itself. Is this true?
Second, The start/stop button that stops the engine when at a red light, I can never have it remember the last setting. Every time I start the car it defaults to off, meaning the car will stop when I'm at a red light. Dealer mentions that this is the way it was implemented. That doesn't sound right to me. Can anyone comment on that?
Any help would be appreciated!
1) True (though I don't know about the whole life comment) it does stay on a little long
2) Yes, that is how it's been designed. You need to turn it off every time the car starts. Becomes second nature
Max
1) Back up Camera Delay- There is a setting for this in the Infotainment system. I don't remember what the settings are but you can adjust it. Like it on longer because I use it to make sure I am pulled into the Garage far enough. Pull in, put it in reverse to bring up the camera and either back up just a little or change to drive and pull forward just enough.
Reactions: Il_Conte
Congratulations !
When I get on my car 1 step 3 buttons: brake paddle, then start button, park button and the s/s disable button - like what Max said, it will become a routine :)
If you want to save one click on the disable button there is a hard way. Search on this forum and a very smart senior member figured out how to disable it :)
do it your way whatever it is and happy motoring.
Woodstk is correct, there is a camera delay setting on the QV. Mine goes off immediately when you put it in Drive. I have the same habits as some of the others here, as soon as I get into the car I turn off the "auto-start\stop" feature ....
1 - 7 of 7 Posts
