1 - 20 of 41 Posts
Hello 馃憢馃徏
i have an EMEA Giulia MY 16. I have activated remote start (Thanks this forum) and have some question.
I knw in newer Giulia鈥檚 when outside temp is on a certain level, the Giulia automatically activates Seat and steering Wheel heaters and the back windows defrost.
is this possible to use on an older Giulia? I know I have the actual software on HVAC ECU.
i remember you could activate this feature in the ETM, but I don鈥檛 remember the name.
I have fitted the 2nd generation ETM because of carplay if this is interested.
is there maybe a proxi who activated the menu
Thank you 馃檹馃徏
can't remember how exactly menu is called but I think you'll need CSWM module with at least SW9.00 to enable it. and also proxi changes
Thank you
I think I have old CSWM Modul because the comfort seat deactivation didn鈥檛 worked.
The menu appears but have no effect.
so I think I have the old version. I check it
In MES under Info tab for CSWM you'll see which SW version you've got.
That's the option you were looking for - "Auto-On Driver Comfort" under "DRIVER ASSISTANCE"
105717
I can't 100% confirm as still need more testing but from what I've seen only cars with CSWM SW9.00 have this option so must be dependant on CSWM.
Hi
I not have this menu and have CSWM with SW 9.0
Enviado do meu iPhone usando o Tapatalk Pro
Hi
Hello ratix
dou you have original remote start?
i think it鈥檚 only activated on US Giulia
is it possible to update an old CSWM?
If I remember last time there was no update at WiTech for my car
I activate remote start
Is a European car
I buy a new SCWM because the original unit not have update
Hi
@ratix check PM
@fiatpanda, remote start from factory only available on NAFTA market. Rest need new keyfob and coding.
As for CSWM module update, looks like you can't update it to support easy entry or auto-on comfort although all of the CSWM I've seen so far are identical inside on hardware level - HW3.01. It has something to do on software level.
I think I have the old CSWM.
Where is it mounted at the car ?
if I remember it costs about 150鈧 +vat for the new module. The numbers have been changed so I think I will get the new generation.
Do you know the proxi?
Befor I buy it 馃檲
Is a European car
same as me.
I think this option is only preactivated on native remote start nafta cars.
sure there is some byte to change.
Shpuncik
You have PM
The hardware looks the same
Inside have one NEC upd78f1833
I go put in the old CSWM the new software
Discussion Starter · #13 ·
@ratix
how do you get the software and update it if in witech there is no update available ?
whete I can find the cswm In the car ? Under seat?
Discussion Starter · #19 ·
So i have :
FIAT Number 50537139
HW 03.01
SW 07.00
50537139 is changed to the new number 50557150.
So if I want to upgrade to SW 09.00 I have to buy new CSWM.
is the CSWM vin locked ?
Or can I test from another Giulia before buying it ?
@fiatpanda, yes, there is VIN inside but used module works on other car just fine at least those I've tested.
1 - 20 of 41 Posts
