For MES use, an OBDLink SX USB. $30 on amazon.What interface does everyone use?
Hello ratix,Panic button not work !
is another byte but I haven't figured it out yet
Hi, Can you share how to connect OBDLink SX?For MES use, an OBDLink SX USB. $30 on amazon.
Make sure you're reading through the MES user manual, it goes over setting up the COM port settings and selecting the proper device in MES. (LINK)Hi, Can you share how to connect OBDLink SX?
I had an error and don't know how to solve it View attachment 111616
I changed to this setting and error still exist.Make sure you're reading through the MES user manual, it goes over setting up the COM port settings and selecting the proper device in MES. (LINK)
Do you have the colored adapter cables?I changed to this setting and error still exist.
Yes, I do have them. But I don't need to connect with the colored adapter cables when first connecting to the software right?Do you have the colored adapter cables?
depends on which ecu you're trying to connect to. On the MES site you can see what's needed, see :Yes, I do have them. But I don't need to connect with the colored adapter cables when first connecting to the software right?
Thanks, Looks like I don't need the adapter to connect for the module. But error still exists.depends on which ecu you're trying to connect to. On the MES site you can see what's needed, see :
(A5=blue, A6=gray)
yes, bodycomputer access would be without adapters, just the interfaceThanks, Looks like I don't need the adapter to connect for the module. But error still exists.
I have not bought MES yet, but do they also need a SGW bypass for it to connectDo you have the colored adapter cables?
Very probable.....I have not bought MES yet, but do they also need a SGW bypass for it to connect
without an error if the car was built late 2018 or newer?
Hi, Alex from Italy here.Panic button not work !
LOVELY, thanks, going to test it this eve.Hi
Byte 126 00->A0
Enviado do meu iPhone usando o Tapatalk Pro
80 should do the trick. A0 enables panic but disables front wipers after-wipe function.Hi
Byte 126 00->A0
