JB4 map 2. Cold air/ram air mod. GFB+ CAT BACK. MADNESS go pedal. Consistent logging at 25 to 28 psi at 6300 rpms......
I did type wrong on rpm. Fat fingers. But here ya goYoure not seeing 28psi at redline on stock turbo.
Giulia 2.0l redline is at 5800rpm. You have a tune that increases your redline to 6300rpm?
Thats 22psi at redline of 5800rpmI did type wrong on rpm. Fat fingers. But here ya go View attachment 128588
Do some logs in 4th gear or higher. Things happen too quickly in first gear and not enough load.I did type wrong on rpm. Fat fingers. But here ya go View attachment 128588
Blue line is boost. How is that 22? View attachment 128591
I just installed new firmware to adress afr and ign. So I'll test tomorrow. Your 22psi argument is invalid40 to 90...per request from jb4 View attachment 128882
That log shows 22psi at redline. Just post the spreadsheet on Google drive and you can read the boost at 5800 but see below.40 to 90...per request from jb4 View attachment 128882
You're wrong.Ok. One of us can't read the difference between INTAKE TEMP AND BOOST. LMFAO.
Apparently not. Royal blue line is boost as both arrows point to.Ok. One of us can't read the difference between INTAKE TEMP AND BOOST. LMFAO.
It is spiking to your peak boost at a low rpm, but there is no way that it is holding that same boost level close to redline. Blue line is boost.I mean honestly not looking to argue. Maybe I don't know how to interpret these logs. But even my boost gage spikes up over 30. Does it hold...no, of course not. My whole point has always been that with the build I AM getting boosts past the stated 22.
Thats not been your point. Your point was clear...I mean honestly not looking to argue. Maybe I don't know how to interpret these logs. But even my boost gage spikes up over 30. Does it hold...no, of course not. My whole point has always been that with the build I AM getting boosts past the stated 22.
And its incorrect. No big deal.JB4 map 2. Cold air/ram air mod. GFB+ CAT BACK. MADNESS go pedal. Consistent logging at 25 to 28 psi at 6300 rpms......
Got it. I'm new to turbos.Thats not been your point. Your point was clear...
We all know the turbo spikes at low rpm. It doesn't hold boost though. Its too small.
No biggie at all. Check your excel spreadsheet and compare to the graph results and it helps make sense of it.Got it. I'm new to turbos.
Maybe at some point it would be nice to have a phone conversation? You could probably help me understand exactly how this all worksNo biggie at all. Check your excel spreadsheet and compare to the graph results and it helps make sense of it.
