Just an FYI, The HPFP is not electric ,its mechanical.
Just an FYI, The HPFP is not electric ,its mechanical.1 tank of E85 will do nothing to gall or cause rapid wear to an electric fuel pump. Gasoline doesn’t lubricate an electric fuel pump. Your diesel injector pump is a whole different animal. They are big money and typically warrantied for 5-7 yrs or 100K miles.
I stand corrected on the electric pump.Just an FYI, The HPFP is not electric ,its mechanical.
The electric low pressure fuel pump is most likely diaphragm based. Nothing to gall, just a piece of rubber that may or may not react badly to E85.I stand corrected on the electric pump.
Unless it was from a can it is not full E-85. Pump E is usually between e51-e70. Especially now during a gas apocalypse. So after mixing it with whatever fuel he has in system he most likely around E40-50. Like others said stay in low boost and should be fine. Fill it up at half way again. Cars seals and rings etc are designed to handle ethanol in everyday gasThe rubber and seals have been made to handle ethanol for quite a few years now. The problem is the car will only adjust the fuel trims so far and then set the check engine light. You. CAn get away with E30 just fine and car will adjust perfectly to it. E85 however the stft and ltft will be too far out of tolerance. And pop the cel on.
When tuning and having a intermittent problem with know we usually will throw in a few gallons of E85 to see if the knock goes away. That will let us know if it’s false knock or not like loose motor mounts or headers hitting something and such.
Nope. Cars from the recent past have some kind of restriction or valve that prevents from inserting the siphon hose. AMHIK.Talking about draining the tank, isn't the old school SOP of putting a low diameter hose through the top of the tank (gas cap orifice) and suck the gasoline (and trying not to swallow anything) an option in these cars?. One only needed a hose and a big gas plastic can (or two) to empty almost all the tank. Isn't that possible these days?. One could even sell the wrong gas and the plastic gas cans to other who could use it.
I find it difficult to believe that pump fuel is not as advertised. We are not talking about E unknown, but fuel advertised as E85. At least in California there is pretty strict oversight that pumps dispense the right amount of the right fuel. Otherwise you will end up getting the same fuel when you select 87, 89, 91 or 93 octane, just for different prices.Unless it was from a can it is not full E-85. Pump E is usually between e51-e70. Especially now during a gas apocalypse. So after mixing it with whatever fuel he has in system he most likely around E40-50. Like others said stay in low boost and should be fine. Fill it up at half way again. Cars seals and rings etc are designed to handle ethanol in everyday gas
E85 is different. They have seasonal blends that change the ratio and octane. You can look it up and go by a calendar really. Problem is E85 don’t like the cold and don’t like to start. So they add more gas to it essentially lowering the ratio from 85% to like 65-70.I find it difficult to believe that pump fuel is not as advertised. We are not talking about E unknown, but fuel advertised as E85. At least in California there is pretty strict oversight that pumps dispense the right amount of the right fuel. Otherwise you will end up getting the same fuel when you select 87, 89, 91 or 93 octane, just for different prices.
Some pumps say E-51 to E-83. Ethanol isn’t regulated Like others have stated. Only way to get full E-85 is from can or at a track. The best you may see on a pump at a station if your lucky is 80-82. And believe me those stations sell out quick. Because of the wide range Most tuner cars have a ethanol gauge to sense what the E level is.I find it difficult to believe that pump fuel is not as advertised. We are not talking about E unknown, but fuel advertised as E85. At least in California there is pretty strict oversight that the pumps dispense the right amount of the right fuel. Otherwise you will end up getting the same fuel when you select 87, 89, 91 or 93 octane, just for different prices.
Correct. Youll almost never get exactly e85 from the pump which is why all e85 compatible cars must have ethanol sensors in them that continuously assess etoh content.Some pumps say E-51 to E-83. Ethanol isn’t regulated Like others have stated. Only way to get full E-85 is from can or at a track. The best you may see on a pump at a station if your lucky is 80-82. And believe me those stations sell out quick. Because of the wide range Most tuner cars have a ethanol gauge to sense what the E level is.
Better safe than sorry !!’I mistakenly filled my gas tank up with E85 this morning. I am uncertain if I should drive the car or have it towed to get the gas tank flushed and new 91 gas put in. It is a 2019 Q4 Giuliani. I am at the gas station and uncertain what to do.
I preferred the 1996 Giuliani.Giuliani??? Gotta love autocomplete.
