1 - 20 of 55 Posts
Introducing the MADNESS XXTREME Edition Coilover Suspension Kit by V-MAXX for the Alfa Romeo Giulia!
Are you guys ready for this? The coilovers we have been testing on our own Giulia for the last couple months is now finished and ready for you to install on your own Giulia!
This kit gives you;
20+ levels of dampening adjustment
30-70mm of drop in the front and rear
and vastly improved handling
Our MADNESS XXTREME by V-MAXX Coil Overs Kit not only offers you an excellent value for money, but it completely transforms the look, handling and ride of your Alfa Romeo Giulia!
Currently, this kit only fits the Q2 but the Q4 version will be ready by the end of 2018!
More information and pricing can be found on our website
https://madnessautoworks.com/2017-Alfa Romeo-Giulia/start-shopping-cid1/new-arrivals-cid2/alfa-romeo-giulia-coilover-kit-madness-xxtreme-by-v-maxx-pid8855
What have you chosen for the spring rates? Are there any plans to offer something in the way of front camber adjustment?
Discussion Starter #7
Coilovers do not control wheel camber but we do have an upper control arm kit that will allow you to set a custom camber.
Those can be found on our website;
https://madnessautoworks.com/2017-Alfa Romeo-Giulia/start-shopping-cid1/suspension-brakes-cid8/alfa-romeo-giulia-adjustable-camber-upper-control-arm-kit-pid7684
I know we have a few differences but why is it the Q4 needs its own set? @MacGeek had explained it once but I can't find the thread.
Long story short; AWD vehicles have a different suspension setup to accommodate that AWD. Thus they require a different coilover design.
Let us know if you have any other questions
Discussion Starter #9
Won't work with LSD right?
An LSD does not change the suspension. That is a drivetrain item. So yes you can install these on a RWD Giulia with an LSD.
Discussion Starter #10
As an FYI to you and many other Q4 Owners that would like a set we are working on a version for you as well. We estimate 3-4 months from now.
Discussion Starter #11
Better check with your doctor first ;)
Our MADNESS XXTREME by VMAXX has not been evaluated or tested by the FDA. If you have a prior condition that may be affected by improved handling and stance of your Giulia please call us at 512-982-9393 for advise. LOL! ;-)
Discussion Starter #12
We chose to go with a Progressive Spring Design. In this type of a design the spring rate varies as the springs movement can range between +/- 74 kg/ cm up to 105 kg/ cm (414/in to 588/in). The springs for this kit are designed to accommodate a wide range of driving height, driving style and road condition.
In a coil over set up spring rates are always significantly higher than standard or performance springs since they are significantly different in size and design.
We will post a couple of detailed graphs to help explain better in the next post. Hopefully this will help.
Discussion Starter #13
Here are the detailed graphs that further explain the testing results for those that would like some detailed information on the specs.
This kit gives you;
WOW! Looks great the car is sitting on 20" rims? if so how wide is it 9 or 10?
Discussion Starter #16
Those are 20x8.5 in the front and 20x9.5 rear and dropped about 2".
Discussion Starter #20
How's the ride not so bone jarring? maybe I will go with a 19" rim. Two inch drop would still be ok right no spacer needed? Sorry if I have to many questions only had my car for 3 weeks.
We can't say for certain that you will need a spacer or not. Wheel size, tire size, and suspension setup all play into that.
The ride in our Giulia is great. In fact, that is a daily driver with two child seats in the back. If it is smooth enough for a toddler then it should be smooth enough for most people.
1 - 20 of 55 Posts
