41 - 51 of 51 Posts
I have a rhd 2.0 MAir and require new seals to/from the secondary coolant reservoir due to loss of fluids. Apparently, the turbo cooling reservoir. It has't affected performance so far although I haven't done any long distance since discovery a day or so ago. Not even 10,000 kms on the car. Sounds like it might be a generic problem requiring a recall as it seems I am not alone.
It is, from already quite some time ago ;) :
o-ring replacement.pdf
Whatever engineer decided to develop a new antifreeze that would gel when mixed with any old antifreeze should be fired. What was the purpose of that? This is worse than apple changing the charging cable to be incompatible with older ones.
A lot of Fiat-Chrysler cars had to deal with this. Lots of Jeep Wrangler folks screwed up their cooling system adding the wrong formula, including a lot of dealers. Bottom line, watch what you or anyone else adds to your system. Make sure you add OAT formula stuff. Should be Mopar dealer stock. They use a lot of it. I only wish they kept the dye consistent. It seems to vary by world region.
More specific than OAT...
... see the details in thc Coolant/Fluids thread:
https://www.giuliaforums.com/forum/...scussion/33762-engine-coolant.html#post558898
Mopar Purple is the best value. I used the Ravenol Concentrate at 50% dilution.
Hope to help,
It’s not the line, looks to be the valve that connects the two line, it just started.. have any clue on the costs . Seem to be a easy replacement. I’ve replaced a lot harder on my M5 lol
Correct but if I recall correctly, Alfa only sells the whole line with the valve.
If you search on here (and it isn’t under warranty) I believe some people have just replaced the line with aftermarket and not bothered with the valve at all.
I ordered the line and it’s nationally back ordered for 30 days.. just have to wait for it to come.. that valve must be faulty if it’s on back order
41 - 51 of 51 Posts
