I noticed last weekend that the coolant in the reservoir on the passenger side in quite below minimal level. The reservoir in the front seems to be fine. Anyone has seen the same thing?
Yes I just saw that last weekend on mine..I noticed last weekend that the coolant in the reservoir on the passenger side in quite below minimal level. The reservoir in the front seems to be fine. Anyone has seen the same thing?
You're probably referring to the Engine Coolant Reservoir assuming you live in the USA and drive a LHD car.coolant in the reservoir on the passenger side
Checking Levels
Engine Coolant Fluid
If the level is too low, unscrew the cap of reservoir and add the fluid described in the "Technical Specifications" chapter.
DEALER SERVICE
Cooling System
Warning!
You or others can be badly burned by hot engine coolant (antifreeze) or steam from your radiator. If you see or hear steam coming from under the hood, do not open the hood until the radiator has had time to cool. Never open a cooling system pressure cap when the radiator or coolant bottle is hot.
Keep hands, tools, clothing, and jewelry away from the radiator cooling fan when the hood is raised. The fan starts automatically and may start at any time, whether the engine is running or not.
When working near the radiator cooling fan, disconnect the fan motor lead or turn the ignition to the OFF mode. The fan is temperature controlled and can start at any time the ignition is in the ON mode.
Coolant Check
Your vehicle has two cooling systems and they both need to be checked to ensure they are at proper fill levels. Refer to the “Engine Compartment” section for the locations.
Check the engine coolant and intercooler coolant level every oil change or before long trips.
If there are impurities in the engine coolant, the system must be drained, flushed and refilled: contact an
authorized dealer.
Check the front part of the condenser to check for any build-up of insects, leaves or other debris. Should it be dirty, clean it by spraying delicately with water.
Check the hoses of the engine/ intercooler cooling system to ensure that the rubber has not deteriorated and that there are no cracks, tears, cuts or obstructions in the expansion tank side and radiator side connectors. Should there be any doubt regarding leaks from the system (e.g. if frequent top ups are
required), have the seal checked at an authorized dealer.
With the engine off and at normal operating temperature, check that the cooling system radiator cap is closed properly.
Warning!
Do not open hot engine cooling system. Never add engine coolant (antifreeze) when the engine is overheated. Do not loosen or remove the cap to cool an overheated engine. Heat causes pressure to build up in the cooling system. To prevent scalding or injury, do not remove the pressure cap while the system is hot or under pressure.
Do not use a pressure cap other than the one specified for your vehicle. Personal injury or engine damage may result.
Note: Before removing the coolant reservoir cap, wait for the system to cool down.
Topping Up / Draining / Flushing The Engine/Intercooler Coolant
If the engine coolant (antifreeze) is dirty, have cleaning and flushing carried out at an authorized dealer.
See the "Maintenance Plan" for the correct servicing intervals.
Note:
For topping up, use a fluid with the same characteristics as those indicated in the "Fluids And Lubricants" table (see "Technical Specifications" chapter).
Do not use pure water, alcohol-based coolants, corrosions inhibitors or additional anti-rust products because they may be incompatible with the engine coolant and cause the clogging of the radiator. The use of propylene glycol-based coolant is also not recommended.
Engine Cooling/Intercooler System Cap
To prevent loss of engine coolant, make sure that the expansion tank cap is closed. If it is open, screw it completely until you reach/hear the click.
Periodically check the cap and clean it from any foreign bodies that may have deposited on the external surface.
Warning!
Never add coolant with the engine hot or overheated.
Do not attempt to cool an overheated engine by loosening or removing the cap. The heat causes a considerable increase in pressure in the cooling system.
To prevent damage to the engine, only use the engine cooling circuit caps provided.
Disposal Of Used Coolant
Disposal of engine/intercooler coolant is subject to legal requirements: contact the appropriate body to determine local regulations.
Note:
To prevent the fluid from being ingested by children or animals, do not keep it in open containers or pour it on the ground. If ingested, contact a doctor immediately. Eliminate any traces of fluid from the ground immediately.
When the vehicle stops after a short trip, steam may be seen coming out from front of the hood. This is a normal phenomenon which is due to the presence of rain, snow or a lot of moisture on the surface of the radiator.
With engine and system cold, do not top up with coolant beyond the maximum level indicated on the
reservoir in the engine compartment.
FLUID CAPACITIES
2.0T4 MAir Engine
Engine cooling system 2.2 Gallons 8.6 Liters
Intercooler cooling system 1.1 Gallons 4.3 Liters
Chassis Lubrication
Use: Engine coolant
Features: CUNA NC 956-16, ASTMD3306
Specification: MS.90032
Applications: Use rate50% Not mixable with different formulation products. (*)
(*) For particularly harsh climate conditions, a mixture of60%product and40%distilled water is recommended.
Let me understand. So, if I top off the orange (from the factory) with the purple (from the dealer), this combination might gel?It seems this is the Purple OAT, which replaced the Orange (factory fill) or Pink (OTC) OAT in earlier Mopars. A specific warning against mixing the two is mentioned, suggesting the combination might gel. Be aware that some Mopar dealers mistakenly suggest MS.12106 (Orange) is compatible with MS.90032 (Purple), this seems most common at Jeep and Dodge dealers.
The factory fill, starting with 2013’s, should be Purple (possibly excepting some Jeeps). The Orange factory fill was 2012 and before.Let me understand. So, if I top off the orange (from the factory) with the purple (from the dealer), this combination might gel?
The color is a light orange. SeeThe factory fill, starting with 2013’s, should be Purple (possibly excepting some Jeeps). The Orange factory fill was 2012 and before.
Thanks for the info, but2017 Owners Manual, page 254, specs “CUNA NC 956-16” “ASTMD 3306”, meeting “MS.90032”, use rate 50% (harsh 60%), no mix with other products.
MS.90032 is the current (post-2012) spec Mopar OAT. Part numbers seem to be:
“StarParts Tech states the following info:
1 Gallon - 68163848AA (concentrate) 68163849AA (50/50); MOPAR® Antifreeze/Coolant 10 Year/150,000 Mile Formula OAT (Organic Additive Technology) or equivalent meeting the requirements of Chrysler Material Standard MS.90032”
Lockem, I don’t see a Petronas Coolant that meets this standard. The “11” and the “UP” are both meeting older and incompatible standards. I didn’t see another listed, so for now, Mopar fluid is the easy choice (meeting MS.90032), but I’m sure there are aftermarket option. The trick is finding and verifying them.
Yep, it's sucking alright. I couldn't find a Petronas coolant avaiable to us here that met MS.90032, just ones that meet MS.12106. As for the colors, that's a complete mess. I know Peak advertises that it's "Yellow" coolant won't change any factory coolant color, for instance. The Paraflu Up meets MS-12106 and CUNA NC 956-16 and ASTM D Type 1. Paraflu 11 seems to be the non-OAT and Paraflu HT is OAT but doesn't list any MS. spec and doesn't list ASTM D at all.Thanks for the info, but
Reference post #5 of this thread: the car comes filled with orange coolant. MacGeek says it is Petronas coolant, and the information he provides is pretty reliable.
CUNA NC 956-16 and ASTMD 3306 seem to just specify an ethylene glycol base (not a lower toxicity xxx-glycerin base). It appears that MS.90032 is the key spec to meet. I don't think the color matters, it is what is on the package label that matters. At least one source says each mfg uses a different color so that the origin of the coolant can be identified. In any case, I would trust the MS.90032 spec to be necessary and sufficient. I'll probably have to hit up the Dodge dealer for it, then find out that their parts markup is just as bad as Alfa's.
I guess with modern coolants mixing different formulations is a big no-no. What happens 10 years from now when they no longer make the original formula?
Having killed a Toyota 4Runner with coolant issues, I'm now sensitized to the issue.
I can't disagree, mine's orange too! However, everything I can find says it should be purple...so I'm gonna start calling orange purple and hope for the best?The color is a light orange. See
http://www.giuliaforums.com/forum/attachment.php?attachmentid=58977&d=1520348805
Orange is the new purple. I'm planning to go by the dealership this week and get a quart. Details will follow.I can't disagree, mine's orange too! However, everything I can find says it should be purple...so I'm gonna start calling orange purple and hope for the best?
