I have an early QV ‘17 with 18K miles.
Make sure you still have warranty left and buy an extended warranty.
Remove aftermarket parts prior to visiting the dealer for warranty repairs. Even a cat-back exhaust can void the warranty even though it implies it doesn’t in the warranty manual, ask me how I know.
They are enjoyable but I have had multiple issues with my Quadrifoglio ‘17 requiring multiple visits and warranty repairs, I’m now with the extended warranty which makes replacements a pain because you have to get pre-approval and in my case a $100 deductible:
- Dome light replaced (to correct alarm going off)
- Battery replaced (auto start/stop not working)
- Wire harness connector replaced to fix constant service electronic damper light (required 4 visits to finally find problem and get it fixed)
- Fuel pump replaced (electronic throttle control light while driving, car defaulting to N mode, car wouldn’t start when hot)
- Accessory belt and pulleys replaced due to whining noise
- Exterior door handle replaced due to lock button getting stuck
- Radio replaced because after a software update it wouldn’t upload gps maps in spite of dealer attempting multiple ways
- The latest was that 2 1/2 years after the wire harness connector was fixed to eliminate the service electronic damper light, it started appearing again and I had 1 shock replaced (didn’t fix the issue) and then the electronic module replaced (so far fixed the issue)
Minor things:
- The hood release handle is not sitting flush anymore under the dash in its resting posand should be replaced but is a minor thing and will fix at some other point
- Software update to have the oil level properly display on the dash
- Software update to have the MPH display on the center dash while on Race mode (it is standard in the later models)
Major issue:
I had an axle-shaft failure at its junction with the differential, it was not covered under warranty because the dealer stated the axle shaft was touched by the other dealer that installed the exhaust, which doesn’t make any sense, but that is a discussion for another day.
My sincere advise is pay more for peace of mind and get a late ‘18 with more factory warranty left.
