Rear plate install – You would think this would be an easy one – screw in all 4 screws into the plate with an optional frame and you’re done right? Nope. Although the dealer is technically suppose to put your plates on for you, I like to take these minute details into my own hands (and avoid a tacky dealer plate frame). Unlike most of the world with sleek & thin good looking plates, here in the US we have hideous fat rectangle licenses plates. To install the rear plate you are only able to screw the top 2 screws. I tried putting on a mounting bracket but still was unable to screw it in to the bottom plug caps (don’t try they won’t unscrew, trust me). I believe the best solution is to get a sturdy plate frame that allows you to screw in the top 2 and also hooks the plate into the frame from the bottom ensuring you don’t cover up any lettering at all on the bottom (check your local state laws, any letters covered up is a violation in most states), Adding a piece of Velcro on the back will ensure it doesn’t rattle when you close your trunk or pump the bass to the point of shaking the rear (please don’t, we want to make a good impression as new Alfa drivers). I was told the soft Velcro in this case would be better than the stiff Velcro you would apply an EZ pass to.
TL;DR: Screw your plate on
Front plate - Dealerships in states that require a front plate should provide a plate bracket which I believe would go over the driver side. I personally think it looks better over the passenger side so I ordered the plate mounting bracket from Alfa 9 supply, very high quality. To install remove the tow hook cover by firmly pressing on the top, then once off just slide the little clip attachment off from a plastic string thing. The rest of the directions would come with the kit. Easy install overall and looks as good as a front plate on a Giulia would. Pays for itself immediately as a front plate violation would be around $100. Yes, in my area they will ticket you for this - yes, even in an Alfa.
TL;DR: Front plate on an Alfa…you’re joking right?
