No, if you've seen the work done by Tucoschild you'll see that his suspension engineer buddy said that a 17mm spacer on the 10" wide wheels was ideal... but that's also after adding adjustable upper control arms, -3.5° - -4° camber, and moving the axle center back a handful of mm's (6mm maybe?).Wouldn't that compromise handling? If I remember correctly, it's been mentioned that the Giulia seems to be optimized for a rear track around 12 mm wider than the front, based on the offsets of the staggered wheels.
yes, 10" wide techino's in the front.
