1 - 20 of 26 Posts
Hello all. I received a JB4 for my 2020 2.0 this week and I am about to install the tuner, but need some advice on disconnecting the points as circled in the following photo on the second engine cover. I know to remove the two bolts first, but what about these connections with the braided lines. How do I remove the clips without breaking them?
102229
Any responses are truly appreciated.
Discussion Starter #3 (Edited)
Thank you! That worked. It turned out there were four connection points similar to the two in my original photo. All needed to be unclipped to remove the cover. Is that different for 2020 or have all model years had four?
102278
Install is complete. The hardest part was getting the harness off the sensor on the charge pipe, but I generally don’t wrench on my cars so am humbly not the most experienced in this area.
So far so good using map 1. No CELs and a definite improvement in power! It is 90 degrees here right now and I am looking forward to testing on a cool morning.
I also hope to run this car at the drag strip in September to test maps 0, 1, and 2.
Discussion Starter #4
For fun, I used the JB4 to time a 0-60 run this morning. Outside temp about 70 degrees F. Slight incline to the road. JB4 firmware version 29/5//5, Map 2. Brake boosted to about 2,500 rpm with part throttle and hammered it. Ran a 4.675. Very pleased!
102772
Discussion Starter #5
I emailed the log file to Terry for him to review and he replied literally within five minutes stating everything looked great! Posting up the graph.
102775
Discussion Starter #6
This is interesting. Today at the same location with the temperature around 55 degrees, brake boosting with gas pedal all the way to floor, and launching at 2,779 rpm (according to the log) I ran a 4.4 0-60. I really need a Dragy.
I am very impressed with this AWD system. It just sticks and goes with no wheel spin or drama. Super fun.
103067
2019 Alfa Romeo Giulia Ti Sport Q4
Very impressive. Thanks for sharing this. They definitely are great at sticking to the road.
Definitely get a draggy. Dont think we have many awd folks who have done it. That 4.4 would be crazy if it doesnt include 1 foot rollout. Not sure if it does.
very good runs. With the low temps and low DA you should see some big gains.
2018 Giulia Ti
I have a Dragy and the Squadra performance logger, personally I'd skip the Dragy and put that money toward the Squadra product.
great times by the way!!!
Discussion Starter #11
Thanks all! Would I be able to use the Squadra logger with the JB4 plugged in to the OBD port?
What does this mean?! Lol. How does the Squadra logger work?! I haven’t looked at it too much, but thought I saw it plugged in somewhere.
plugs into OBD. So you would need a harness that can support both jb4 and Squadra at same time. I’m not sure thats even possible? I’ve never tried two products at same time. Dragy is the best imo and it doesn’t tie up your car. Used phone. Very accurate. Wayyy more accurate on a consistent basis than Squadra.
Discussion Starter #15
Ok cool, looks like Dragy would be best at this time for me. Thanks!
It's possible, you just buy a dual lead and can tuck the dongle up while the JB4 is plugged in too.
You need to buy a high quality obd2 splitter. I use one to connect the jb4 as well as a bluetooth module to stream data to the infotainment
Early results show the dongle is as or maybe more accurate than the dragy... Plus it actually does other useful stuff
1 - 20 of 26 Posts
