1 - 20 of 28 Posts
Tonight I was driving and some jerk in I think it was a four door Scion tried to pass me on the left . He got a jump on me , He probably had at least a two second advantage on hitting the throttle be me, but to my Chagrin we had got up to around 40 miles an hour , and I was neck and neck with him. I was in drive , so I thought maybe the gearbox didn’t jump down to first gear, only stayed in second, and my Car was In D mode , and I have the madness pedal booster , has anyone had a similar experience with trying to pass somebody at around 30 mph, and can’t pull on a car that has well at least half the HP? Please let me know your experiences.
2020 Giulia
Madness pedal only helps with throttle response (cutting out turbo lag). Dynamic mode remaps shift points and keeps you in a lower gear longer…….. it makes the car more sporty than N mode, but it isn’t suddenly a race car. I’ve found D doesn’t shift down to lowest available gear still shifts earlier than I would. Even after driving around a lot in D, I surprise myself with how quick the car is when I’m controlling the gears. If you’re on a track and racing, “manual” mode is the way to go.
I’m very partial to go-fast machines with proper clutches so I am biased, but that’s my two cents. I look at D mode as a sportier daily driver mode.
Reactions: C.Q4
Did you floor it or ease into the accelerator pedal?
Reactions: C.Q4
You did not mention your RPM level at that speed !!
If your below 2,000 RPM you won't get the rite Nm you looking for
Are you sure it was a Scion? 4 door Scions looked like cubes or big hatchbacks.
I mean, anything can be modified, and the Giulia 2.0 isn't really a quick car. Throttle mapping just changes the responsiveness (amount of pedal travel required, example 50% travel = floored normally), it does not give you more maximum hp/tq/psi.
What gear were you in? These are turbos, you can't be in a high gear (low RPM) and expect a ton of thrust. There is turbo lag. Did you launch the car? Did you floor it the whole time? A lot of variables, including, what the other car was/is putting down.
2020 Giulia QV
Did the "Scion" look like this? I know a few people seem to mistake Stingers for Scions for some reason, and they have 300 - 368 hp. It would make sense in context. Really you can get around 300 hp from a stock Camry, Sonata, K5, and a few other somewhat mundane looking cars at this point. While stoplight racing is bad, at least you looked better doing it.
years ago, when I had a 500+ HP Superformance 427 Cobra, I had immense low rpm torque, but my stoked engine was out of breath at 5K rpm. Sometimes, I would come alongside some turbo car of the era, and we would give it a go from some highway speed, say 60 or 70 mph. With my instant torque, I would leap out for just maybe two seconds, and then ease up off my throttle while the turbo car was waiting for his turbo to spool up. If a turbo car isn't "spooled up" it is dead meat for a non-aspirated car. I had a '90 Mitsubishi AWD turbo Eclipse, and put on a bigger 16 G turbo, exhaust, fuel controller, and more. It was a quick car for its time, and even more so with my mods. But with all that, if I anticipated any need for immediate thrust, I needed to downshift a few gears to get my turbo spinning.
Even my QV is pretty lethargic below maybe 3000 rpm. So if a turbo driver is caught off boost, he likely gonna be schooled by a NA car from a jump.
For all that, I never ever give or accept a challenge anymore, gave that up years ago. NV
Here is what 500 stout ponies looks like:
2020 Giulia
That’s why in a forced induction car you must always be brake boosting. Always; at all times. Brakes are only there for boosting. Stopping is for pussies. You might as well run your car into a cement barrier if you lose anyways.
Be like this guy:
2:25 for the fireworks show.
2020 Giulia QV
Be like this guy:
Untill... (not directly related sort of 4:49 for the toasty part)
2021 Giulia Sprint
  • Haha
Reactions: AlfaRocket and C.Q4
Discussion Starter · #14 ·
No, It definitely isn’t a Stinger , or A GT for that matter, way more boxy looking .
2021 Giulia Sprint
In reverse on snow?
Yes! Scandinavian flicks while reversing is seriously next level bucket list stuff. The Scion never saw that coming!
Reactions: Chipshot
2018 Giulia Q4 TI
I did a dig against my brothers 500 Abarth (intake, bigger wastegate, increased boost), he had the jump, and I was playing catchup after that.
At the time all I had was the BMS filter, in D mode, and the car had to down from 6th to 2nd; while he was already in 2nd gear.
He won't rematch with me manual shifting and being in the correct gear.
1 - 20 of 28 Posts
