It's part of my precheck takeoff. Parking brake off then auto start off.Why everyone isn't disabling this, is beyond me. Its harmful to the car. I read a description of what happens in a GM car (Chevrolet) as part of this system - all the things it has to engage (including a supplementary pump to mind the transmission while the engine is off). When I read that, and knowing you cannot defeat the system on a Chevy, I didn't buy the car simply for that reason alone.
I could care less since it doesn't get that hot up here in Seattle.I live in AZ. The auto start / stop is no longer working. For those in the hot states are you experiences the same issues. Those states recording 105 degrees and above?
Okay. I will place tariffs on your vidallia onions:smile2: and starbucks:smile2::smile2: Hey, Do we really grow lettuce here? I know we got lots of scorpions and agave but lettuce? Good thing i eat iceburg.I could care less since it doesn't get that hot up here in Seattle.
However, wish you folks in Arizona would stop shipping your infected romaine lettuce to us!
It is suppose to save gas but I was reading a few articles on it since it is becoming more popular in vehicles. The long term impact on the car with the continuous start / stops. Supposedly it is getting better and lubricants for bearings or whatever have been improved but what are the impacts on the starters. There are only so many cycles. I will likely start shutting it off as part of the takeoff procedures once i know it is functioning.Good point. My previous car didn’t have this feature. Something to get used to.
I have been reading the same thing. The only reason I care is because if it is battery related they will replace a failing battery. That is one of the causes of failure but so is environment so I am sure the dealership will argue the heat as being the cause. I will go with that until the fall but at least i have a record of noting it is an issue now. Really even in April when the temps were around where Ryanc383 70-80 it was kicking back on with the foot still on the brake.Why everyone isn't disabling this, is beyond me. Its harmful to the car. I read a description of what happens in a GM car (Chevrolet) as part of this system - all the things it has to engage (including a supplementary pump to mind the transmission while the engine is off). When I read that, and knowing you cannot defeat the system on a Chevy, I didn't buy the car simply for that reason alone.
Why manually release the parking brake? You do know that with the drivers seat belt fastened, selecting D or R will automatically release the parking brake as you release the brake and apply throttle, right?It's part of my precheck takeoff. Parking brake off then auto start off.
Real vidalia onions only come the from Vidlia, GA area. Like champagne, they have a defined provenance.Okay. I will place tariffs on your vidallia onions:smile2: and starbucks:smile2::smile2: Hey, Do we really grow lettuce here? I know we got lots of scorpions and agave but lettuce? Good thing i eat iceburg.
Do you drive a QV? I don't like how the car jumps in that mode. The QV is already aggressive enough when releasing the foot off the brake and applying no throttle. When having to apply throttle to get the parking brake to release makes it even worse.Why manually release the parking brake? You do know that with the drivers seat belt fastened, selecting D or R will automatically release the parking brake as you release the brake and apply throttle, right?It's part of my precheck takeoff. Parking brake off then auto start off.
How much less could you care? I couldn't care less ?I could care less since it doesn't get that hot up here in Seattle.I live in AZ. The auto start / stop is no longer working. For those in the hot states are you experiences the same issues. Those states recording 105 degrees and above?
