1 - 12 of 12 Posts
I originally ordered it from amazon (left on first pic) and then ordered it through Madness (right on first pic) which was much better quality!
ordering mine thru Madness soon, how was the install? just used double sided tape?
3 min install! They recommend an adhesive compound vs 3m tape due to it sliding onto the stock piece easier! I used 3m and as long as you push in hard enough you should be fine!
I have the Mopar carbon-V grill. It looks great and is a little lighter weight than OEM although not really enough to make a difference (80 grams). Imperial Works installed it for me, so I cannot say how hard it was to install. It is necessary to take the front fascia loose to do the R&R. Another forum member had a dealer break his fascia when removing it to replace a headlight assembly, so proceed with caution.
1 - 12 of 12 Posts
