1 - 4 of 4 Posts
Get rid of the lag in your Giulia!
Our MADNESS line of GOPedals help with improving throttle response in your Giulia. This quick and easy upgrade, makes a HUGE difference in the way your Giulia performs.
Find out for yourself why 1,000's of Giulia car owners from around the world have chosen to upgrade their Giulia with one of our GOPedals.We offer several different models and all of them come with a 30 Day Money Back Guarantee!
Follow the link below and check out all the new MADNESS GOPedal Models:
https://madnessautoworks.com
As always if you have any questions please do not hesitate to call us directly at 512-982-9393 Ext:203 (ask for Alan)
92172
Discussion Starter #2
Definitely interesting, as the pedal is laggy from the jump. Can you just alter the modes from the app without installing that physical controller? Also, is this something we should remove prior to dealer servicing?
Discussion Starter #4
We offer 3 different versions of the GOPedal
The standard without Bluetooth which all adjustments must be done via the physical controller and buttons.
MADNESS GOPedal
The GOPedal with Bluetooth is similar in that it has a physical buttoned controller with the ability to connect to your Smart Phone to make setting changes either way.
We also offer the GOPedal Plus a fully Bluetooth model. There is still a small control module/Bluetooth receiver attached to the wiring harness that can be mounted under the dashboard out of sight.
GOPedal Plus - Bluetooth
The GOPedal Plus also has a few additional modes with preloaded maps.
As far as removing for dealer service, the GOPedal makes no permanent system modifications to the engine or throttle sensor. If you wish you can remove the GOPedal system in minutes.
1 - 4 of 4 Posts
