1 - 12 of 12 Posts
It's the new 90 degrees 2.9 lt V6, the block derives from Ferrari's F154 90 degrees V8, has the same bore and stroke with the F154 BB, the version of the F154 V8 used by California T.
The 90 degrees V6 Alfa block has nothing in common with the 60 degrees Maserati V6 block.
Looks like there's still some cleaning up to be done - and this is a pre-production show car / test car / mule. I say that because it doesn't quite look as refined as one would expect these days. For example, note the extra couple feet of wire harness folded over onto itself and zip-tied in place dead center up front between the halves of the air plumbing.
That wire harness is not present on this one, but this one is also pre-production, as evidenced by the opaque black plastic they used for the coolant overflow tank:
Here's a shot with better lighting of the other side - maybe the same car in the OP.
1 - 12 of 12 Posts
