My Veloce has the 19" wheels - 35 aspect ratio at the rear and 40 aspect ratio in the front (cannot remember tyre width). The owner's manual says tyre pressure should be around 33psi front and 34 psi rear but, on the rear door, the label says should be rear 42 psi and fronts 39psi.
When I took delivery, they were all around 40psi and I reduced them after I had read the owner's manual. I only discovered the label (which is on the left hand rear door) when I washed the car at the weekend.
Does anybody know which are the correct tyre pressures to use?
My 159, which also had 19" low profile tyres, has pressures similar to the higher pressures on its label.
Chuckyb,
Chuckyb,
