Has anyone changed their own oil who owns a Giulia Ti with the 280 hp, I-4 turbocharged gasoline engine? Only car I've ever owned that didn't have the procedure in the owner's manual!
According to what I've read, the car was shipped with Pennzoil Platinum LX Euro 0W-30 oil which meets API service category SN as well as ACEA C2/C3 specs. I've not been able to find any in Columbus OH after checking the usual suspects: Walmart, Auto Zone, Advance Auto Parts, NAPA. Advance Auto Parts listed it as IN STOCK at 3 stores but none had it when I stopped in.
The only other oil I've seen that meets all the specs is Mobil 1 X1 ESP 0W-30 which is available locally and on Amazon.
I'd like to know what the procedure is regarding the underbelly cover, the torque spec for the drain plug and does the little ($8) rubber & metal plug washer need to be replaced every time like a crush washer, or can it be reused unless damaged? Any tips or traps?
The Ti apparently uses a spin-on filter. I have found a Mopar oil filter MO-339 and Mobil 1 filter M1-113a that fit according to internet sources. The M1 filter is $10 at Wally World, $15 at the auto parts stores.
Anyone have any thoughts about the Mobil 1 brand vs. Pennzoil brand oil, considering they both meet the viscosity, service category and the European spec for the catalytic converter? There are a few oils that meet the API and ACEA specs but are either 5W-30 or 0W-40 viscosity. I'm not keen on substituting a different viscosity than is recommended. Any thoughts on the subject or source for the Pennzoil brand are appreciated.
