For sale full conversion kit for 2.0 Rear Wheel drive Giulia (952)
With this kit you can retrofit Giulia QV front steel brakes to normal Giulia. Kit contain all you need to do that.
Located in Finland but can send these all over the world with DHL Air Freight. Also insurance (+1% for the value) is possible.
Freight price examples.
- OEM Giulia QV 6 pot brake calipers. Low milage. Checked and painted Gold. Perfect condition
- OEM Hardware to calipers. Plates between pot and brake pads and pad locking pins
- OEM Giulia QV brake steel brake discs. Low milage, almost original thikness, but has stayed outside too long so some small rust spots around the holes (see picture). May need only a bit hard braking and it's fine.
- OEM Giulia QV brake caliper adapters to hub
- New OEM bolts from caliper to adapter
- New OEM bolts from adapter to hub
- OEM Giulia QV wheel hub carriers. Other side is new, other is low milage and perfect condition.
- OEM ball joint bushings to the used carrier side. But these are not needed cos you can you existing giulia ones
- OEM Giulia QV brake dust shields
- OEM dust shield bolts to carrier. Other side only, you can use existing ones
- New HEL Racing braided brake lines (QV has a bit longer than standard Giulia). Carbon black
- New Ferodo DS2500 brake pads for QV
- One bottle AMSOIL brake fluid
- to US 240$
- to Europe, depending of the country. 105-158 $
