That price is terrible.What abt this?? This is API SP as well but with extreme performance so wouldn't this protect the engine somewhat better even though it doesn't have the ms-13340 View attachment 130697
How much are these max pro motor oils??
$13.00 quart at Dodge,Jeep.DealerHow much are these max pro motor oils??
This seems like a great argument for changing oil at 5k. Especially if driven like we do.UPDATE:
We summarized that API SN Plus certified oils were a a stopgap measure to require oils to immediately address low speed pre-ignition by reducing calcium in oils.
API SP certification then came along to cement this LSPI fighting requirement and is complimented by ilsac gf6 testing requirements as well.
Now we can likely look forward to a supplement to API SP in order to address an immediate concern that many API SN Plus and API SP oils are not protecting against LSPI for the duration of a drain interval.
An article from lubrizol may just have sparked an entirely new API SP Plus certification. See it here...
Low Speed Pre-Ignition (LSPI) Durability – A Study of LSPI in Fresh and Aged Engine Oils
Downsized gasoline engines, coupled with gasoline direct injection (GDI) and turbocharging, have provided an effective means to meet both emissions standards and customers’ drivability expectations. As a result, these engines have become more and more common in the passenger vehicle marketplace ovwww.sae.org
What we are likely to see now is oil formulations with very low calcium. Moderate magnesium and very low to no moly or titanium if we want to see long term lspi protection.
In essence, the testing showed oils with low calcium BUT that also contained either moly or titanium protected against lspi when new but as the engine ages they ni longer protect against lspi.
Mike
Lol, in fairness it may be only 2k miles. I don't recall off hand what the 100 hr dyno test simulates for miles.This seems like a great argument for changing oil at 5k. Especially if driven like we do.
I would also like to see which of the oil formulations(only one, of the four) protected fresh and aged in the paper contained in the link you provided. What is this magic oil!? My guess is it uses Lubrizol additives.![]()
I just found out yesterday this one fits the bill as well for my 2017 giulia since it is:Doesn't this oil fit the bill for the 2.0 engine? I don't see many talking about this one..
Well that is what I thought too, but I switched to the Mopar Max Pro+ and wow the engine sounds better. SNplus did not exist when your manual was written. It is definitely better than SN.I just found out yesterday this one fits the bill as well for my 2017 giulia since it is:
1. Ms-13340 or fiat 95535 gs1 approved
2. 0w-30
3. API SN
according to my owner's manual this completely ticks all the boxes.
2. 0w-30
3. API SN
One question keep popping up in my mind, let's say API SP is the new standard against lspi, whats the ms-13340 or fiat 95535.gs1? I mean let say mobil 1 or pennzoil ultra platinum which is SP rated but doesn't come with those ms or gs1 rated. They should b safe to use?? Especially with the ultra platinum which protects against extreme performance too...It does not. All online manuals have been changed to put SN Plus and SP as the bolded required oil spec. Even if you can technically "get away with it" because you're going by your paper manual which came our before SN plus or SP was even a published oil specification, id have to ask why anyone would do that?
That oil will have high calcium and will not protect against lspi. Dont go out of your way to use an inferior oil for your application (not saying motul is inferior itself but it is inferior in our engines unquestionably).
All manuals call for 0w30 and sn plus or sp. Easy peasy.
Chrysler and Fiat specs mean not much. There's not a single oil tested to their specs because unlike mb, bmw, vw, audi, porche, etc that actually certify oils against their standards, fiat and AR do not. Id ignore them and since the manuals only state the sn plus or sp ratings need to be followed for warranty purposes youd be fine doing soOne question keep popping up in my mind, let's say API SP is the new standard against lspi, whats the ms-13340 or fiat 95535.gs1? I mean let say mobil 1 or pennzoil ultra platinum which is SP rated but doesn't come with those ms or gs1 rated. They should b safe to use?? Especially with the ultra platinum which protects against extreme performance too...
Needs at least api sn plus, or api sp.Doesn't this oil fit the bill for the 2.0 engine? I don't see many talking about this one..
