21 - 40 of 43 Posts
· Registered
Discussion Starter · #21 ·
Pulled off of a side street onto a twisty road and pushed it for about 3-5 seconds before the same error warning popped up. Drove it in limp mode home about 5 miles and nothing felt like the throttle needed servicing. Should I just remove the GFB DV and go back to stock? Cycling the ignition did remove the error/limp mode.
also I’ll note that smoothly accelerating to 60 then pushing to 110-120 didn’t throw the code. I did that twice with no error... then proceeded to push it hard from a standstill and that’swhen the code was thrown
I think you may need to just reinstall it again. Make sure you have everything in place (I’m sure you have already but doesn’t hurt to just do that again) tighten the bolts. I’m in Calgary and I do push mine in the mountains to absolute limits and no codes knock on wood. It might just be that, your car needs to get used to of the new upgrade and adapt? Not sure. I did not push mine for about 2 months and it might be that the engine adapted to it etc. maybe a faulty dv? So many variables.
· Registered
Finally installed mine yesterday. I messed up as when putting the one on the passenger bank. With the extra wiring in place due to the Madness Max Power, I removed my finger for a second and the piston shot out. The piston landed on a coolant hose and but I can't find the spring to same my life. I removed the undertray and no dice.
I installed both sides without the springs and ordered three extra springs just to have on hand since they are only $8 and I'm sure I will lose another.
So, for now I am driving without the piston main springs. I do feel that when the boost hits, it hits a bit faster and harder. With a QV, on twisty trafficked roads, there is not a lot of opportunity to go WOT. No CELs or other issues. Now I wait for the springs to see how that feels. It is raining for the next few days so no WOT for now to play with it and get a better feel.
· Administrator
Yep, I just replaced my GFB DV+ with a brand new OEM purge solenoid. I firmly believe that the GFB DV+ is what caused all of my issues at my two day track event at Road America. It may be a good product, it's just that our engines can't handle the change gracefully.
Reactions: bhvrdr
· Registered
2017 Giulia Ti Lusso * Squadra Tune * GFB-DV+ * Custom Exhaust * Madness GoPedal * Race Mode enabled
Just an update. GFB is a must have. I’ve been driving around with it for sometime now and can certainly say this little upgrade has really done wonders for the feel of the turbo.
I just installed the GFB DV+ yesterday. Today I drove it WOT and it felt slower. The OEM felt quicker at WOT. After reading your post, did your car take time to learn the GFB in order to get the full effect?
· Registered
Discussion Starter · #26 ·
Well first before gfb I would always wot to get the boost and certainly it was fast. Then I installed gfb with spring and wot, the rpms go up and that butt dyno was lost. It’s been a couple of months since I’ve had the gfb now and I don’t have to wot to get that same result or the quick spool and full send. Feels quicker, and more stronger Boost if I can get my words right. I’m no expert but I felt the gfb took time to adapt to my driving and don’t think I’ll ever go without gfb.
· Registered
thanks for the reply. I was considering removing the GFB but now I’ll just be patient and see if it approves after a month of driving.
· Registered
Discussion Starter · #28 ·
Honestly for the first 2 weeks I was in the same boat. Confused as to remove or not. Covid hit car sat in garage with minimal driving and i think the car got used to it and honestly, I will never go stock again. This purely because with gfb boost is always available, and now I only have to push the pedal Enough to get an even better butt dyno affect. I don’t know if doing wot has any implications for longevity on anything but certainly I’m comfortable not doing that on a regular basis. Plus I have more confidence know the car will rocket when I need it. Don’t remove it, just make sure you have the spring installed with mild oil lubrication and connections are securely tightened. Comment in couple of moments.
· Administrator
I've said it before, the gfb dv + has given me nothing but problems. I'm very happy to have gone back to OEM.
· Administrator
Reactions: Blazinhassan
· Registered
DV+ that is working properly should not alter performance at WOT, it should only alter the dynamic behavior during shifting. If your valve is leaking internally or externally it could affect the WOT performance.
To get the right behavior the springs need to be installed properly, the o-rings need to be good, the piston needs to be oiled and "perfect", and all 3 of the fasteners need to be properly installed. That bottom screw is difficult to tighten properly, it is fairly easy to cross thread the screws, the o rings are easily damaged and the springs easily fall out of position during installation.
My original OEM valve was sticky and replaced under warranty. Even though I had no problems with the replacement, that experience made me nervous and I installed the DV+ as "insurance". I have not had any hint of problems with it.
When my OEM valve would stick I was using sustained full throttle and then suddenly dropped to 0 throttle (maybe I needed to brake too, I forget now). Sustained full throttle (no shifts) on the street is not a common occurrence unless you are driving at go-directly-to-jail speeds, in my case it was up a steep hill at more than 5000 foot elevation, where 40MPH to some undisclosed speed takes 10-15 seconds.
· Registered
Discussion Starter · #33 ·
I’ve tried dv+ on my Giulia, Stelvio, with And without spring, to me it’s a perfect install. There is night and day difference between DV+ vs stock on WOT. Rpms go way higher for turbo to kick in. Whereas I can get the same affect by depressing the throttle fully, without reaching that wot click
· Registered
Hi buddy
I have the same issue, just installed the DV+ value and my car goes into limp mode as soon as I hit 3000RPM, i I rest the car by pulling negative battery cable it clears but then comes straigh back again, I have tried with and without the main spring with the same issue.
did you ever manage to figure yours out?
thanks
Mike
· Vendor
Alfa romeo 164S, Giulia QV- Squadra
Hi buddy
thanks
Mike
What spring did you use?
· Registered
I tied both with and without the main spring and the car goes straight into limp mode just after 3000RPM, i was carful with parts and havent mixed up the original spring, its very confusing as there is only one way to install it as followed the instructions.
Will trying calling GFB's next week
Mike
· Registered
iv figured it out, DOH! I've accidently ordered the wrong part number T9356 instead of T9366.
I called GFB and they confirmed there are small vent holes in the T9356 and not in the T9366 but the springs should be the same, however was not able to confirm.
I don't suppose anyone has a T9366 handy that they could send me some photo's/dimensions of please as I would like to compare the differences please, if the housing and piston are the same then i may get away with blocking the vent holes, i would prefer to compare first before stripping down the stock one again.
Thankyou
Mike
21 - 40 of 43 Posts
