1 - 14 of 14 Posts
The front parking sensors on my 2017 Giulia Ti AWD are ringing intermittently while I am driving, for no apparent reason. The indicator on the dash flashes the red warning on the screen thereby overriding the radio, etc. Dealer advised me to clean the sensors which I did but problem persists. Anyone with similar issues and remedy suggestions?
The OE front plate holder causes trouble if you have a front plate mounted. I trimmed maybe 2 - 3 mm off the bottom edge using a Dremmel and it got better.
Keeping them very clean is another helpful tip.
If very annoying just disable, the button is above the start stop disable button to the left of steering wheel.
Agree with both of the comments above. I had the unfortunate experience of having this problem on my drive home from the dealer after picking it up.
It turned out to be the license plate frame that had a bottom lip slightly overhanging.
The dealer sent a tech to my house with his tool kit and a new, smaller frame to fix it for me so that I didn't have to bring the car back in for the repair. No problems since.
p.s. Just as an FYI, the front sensors absolutely hate going through drive-thrus. So prepare yourself for more beeping if you use drive-thru ATMs or enjoy fastfood.
If they can't or won't fix it, I'll save you the time of calling Alfa: ""We understand that this is not the answer you were hoping for and do wish we could provide you with a more positive response."
Hi kenalfa17,
We are sorry to hear that you have this concern with the front parking sensors on your Giulia. If this concern persists, we recommend returning to the dealer for a diagnosis. Please message us with your VIN and mileage for further assistance.
Darlene
Alfa Romeo Care Specialist
My Giulia front sensor bracket broke. The one in the grill. I did not hit anything and nothing hit the car. The bracket simply broke. The dealer is telling me this is not covered under warranty and I only have 19k on car. This is ridiculously because this is obviously a manufacturing defect.
This is making it a joy to drive having the sensor go off all of the time
Hi Chuck0065,
I just responded to your post on the thread you made, but wanted to touch base with you here as well. Please take a moment to review my post on your thread when you can, hope to hear from you soon.
Mark
Hi mark. Any suggestions to getting this resolved
Hi Chuck0065,
I just sent you a private message regarding this matter. Please take a moment to review my message at your earliest convenience.
Mark
Hav
Having the same problem on my 2019 Giulia Ti but I do not have a front plate and nothing is obstructing my front sensor. When this happens my info system goes hey wire and nothing is functional in my dash instrument.
Hav
Hello edH,
I just responded to your most recent message on the other thread, but wanted to touch base with you here as well. Please take a moment to review our message when you can. Hope to hear from you soon.
Laura
AlfaRomeoCares
2020 Giulia AWD Ti Stromboli/Gray
if the dealer told you to clean it then get a can of DW-40 spray on the sensor and wipe off with a cloth do this on all the sensors because moisture is inside the sensor and the DW-40 will isolate the moistures or little dirt that may be in there and don't wash you car ever with water spray jet at car wash.Good luck
The front parking sensors on my 2017 Giulia Ti AWD are ringing intermittently while I am driving, for no apparent reason. The indicator on the dash flashes the red warning on the screen thereby overriding the radio, etc. The dealer advised me to clean the sensors which I did but the problem persists. Does anyone with similar issues and remedy suggestions?
mine did the same thing. I found that the sensor was loose and the front cover on the sensor was broken.
1 - 14 of 14 Posts
