Hello yesterday I tried to using Front Defrost Button.
When I pressed it, the degree changed to 'HI'(highest).
Then I was trying to switch this degree lower. but if I changed degree or blow level.
It turned off.
Is this issue or just normal?
Hi abmoon,
This is from your owner's manual:
"Front Defroster And MAX-DEF Function
Push the Front Defroster button (indicator illuminated) to defrost the windshield and side windows.
While in MAX-DEF function, the air conditioner will:
Activate the air conditioner compressor when the weather allows
Turn air recirculation off
Set the maximum air temperature (HI) on both the driver and passenger side
Activate a blower speed based on the temperature of the engine coolant
Adjust the air flow towards the windshield and front side windows
Activate the Rear Window Defroster
Display the fan speed (indicators illuminated) and current air distribution setting
Note: The MAX-DEF function remains active for approximately three minutes once the engine coolant reaches the proper temperature.
When the function is on, AUTO mode will deactivate. The only manual operations possible are adjusting blower speed and turning off the Rear Window Defroster. Pushing the button switches off the MAX-DEF function."
Kori
