Status
Not open for further replies.
1 - 8 of 8 Posts
The information comes either from the Giulia manual(s) or is a summary of discussion threads on the forum. Its written by a US member and deals only with the 2.0 and 2.9 gas /petrol engines so if you have additional info for other countries please add it.
See Oils, Fluids, Fuel, Additives and Lubrications forum
Alfa Romeo recommend an oil and filter change every year or 10,000 miles whichever comes first for all Giulia’s, base, Ti & QV. There is plenty of debate on the forum on the usual oil change topics.
  • Should you change the oil and filter after break in / initial period and what is this mileage? The US versions of the owner’s manual don’t appear to say anything about break in / initial period but some of the European ones mention that for the first 1,000 miles the car shouldn’t be driven at ‘full performance’.
  • Should you change the oil and filter at less than 200 miles because this is when any larger debris will have come loose?
  • Is 10,000 miles too many between oil changes, what is the ‘right’ number?
Opinions and viewpoints abound, if you would like to add some data to the debate please consider getting an oil test kit from Blackstone labs to take a sample of the old oil and posting the results.
See also Break in procedure thread and Oil change after break in thread
Oil Level
The QV’s have a mechanical dipstick and also show oil in the Apps – My Car – Oil level screen. For the 2.0 base and Ti Giulia’s there is no dipstick just the info screen reading.
Type of oil
Alfa Romeo is recommending a very particular and new Fiat/Alfa 9.555351-GS1 specification of full synthetic 0W-30 oil for the Giulia which is currently hard to find.
For the US Advance auto parts now stocks Pennzoil Euro LX 0W30, part number 550043041. Which states that it meets the required spec but you are likely to have to ask for it because at the moment they don’t seem to put it on the shelves.
Shell Helix Ultra ECT C2/C3 0W-30 also meets the specification and appears to be available in the UK
Oil Filter
The 2.0L Base and Ti use a Mopar MO-339 or Mobil 1 M1-113a filter.
The 2.9L Quadrifoglio uses an Alfa Romeo filter cartridge.
You may also need /want a drain plug washer.
Hope this is helpful
Many thanks, Alan. Will add to the main FAQ thread.
Info from jkoval in "Giulia Ti oil change questions" Thread
On the 2 liter engine, the oil change indicator system can be reset by turning car ON, but not starting it. Push the accelerator pedal three times slowly within 10 seconds, then turn the ignition to OFF
Torque spec for the I-4 drain plug was not available, but the V-6 drain plug is 15 ft-lbs, and the drain plug gasket is examined and replaced "if necessary"
You will have to remove underbody cover (covers bottom under engine)
Courtesy of MacGeek:
Alfa does not provide different viscosities based on ambient temperatures.
I am unable to provide the names of products readily available in NAFTA markets. All I can do is tell you what the factory puts in.
Engine Oil
2.0 T4: Synthetic SAE 0W30, API SN, ACEA C2, Chrysler MS-13340, FIAT 9.55535-GS1.
Factory product: FL Petronas Selenia Digitek P.E.
2.9 V6: Synthetic SAE 0W40, API SN, ACEA A3/B4, Chrysler MS-12991, FIAT 9.55535-Z2.
Transmission Oil
Synthetic ATF, FIAT 9.55550-AV5.
Factory product: FL Petronas Tutela Transmission AS 8
Rear Differential Oil
2.0 T4: Synthetic SAE 75W85, FIAT 9.55550-DA9.
Factory product: FL Petronas Tutela Transmission LS Axle Fluid
2.9 V6: Synthetic SAE 75W85, API GL-5, FIAT 9.55550-DA8.
Factory product: FL Petronas Tutela Transmission Axle-Drive
Front Differential Oil (Q4)
Synthetic SAE 75W80, APL GL-5, FIAT 9.55550-DA10.
Factory product: FL Petronas Tutela Transmission Hypoide Gear Oil
Transfer case Oil (Q4)
Synthetic SAE 75W, FIAT 9.55550-DA11.
Factory product: FL Petronas Tutela Transmission Transfer Case
CV Joint Grease
Diff side: NLGI 0-1, FIAT 9.55580-GRAS II.
Factory product: FL Petronas Tutela Star 700
Wheel side: NLGI 1-2, FIAT 9.55580-GRAS II.
Factory product: FL Petronas Tutela All Star
Brake Fluid
DOT 4, Chrysler MS.90039, FIAT 9.55597.
Factory product: FL Petronas Tutela Brake Fluid Extreme HT
Coolant
CUNA NC 956-16, ASTMD3306, Chrysler MS.90032, FIAT 9.55523.
Factory product: FL Petronas Paraflu Up
Windshield Washer Fluid
CUNA NC 956-11, Chrysler MS.90043, FIAT 9.55522.
Factory product: FL Petronas Durance SC 35
1 - 8 of 8 Posts
Status
