Is anyone offering an aftermarket method for keeping the exhaust by-pass open or closed at the driver's discretion? I'm ready!
It is open in race mode, but of course then traction control is off. I thought it might be wise to sometimes enjoy the bypass while maintaining traction control.There should be a tuner or something that'll let you do it ? Sport mode doesn't keep it open ??
I really really really really really wish that the exhaust opened in dynamic. The official description is that dynamic does give a throatier exhaust note than natural, but full on bypass occurs only in race. It's one of those things that likely won't be addressed until down the road a bit.It is open in race mode, but of course then traction control is off. I thought it might be wise to sometimes enjoy the bypass while maintaining traction control.
I have been mucking around for a solution. Should have results posted soon lol.I really really really really really wish that the exhaust opened in dynamic. The official description is that dynamic does give a throatier exhaust note than natural, but full on bypass occurs only in race. It's one of those things that likely won't be addressed until down the road a bit.
I'll bring it up to my customer and see if it's something he wants to try. He's done a whole boatload of modifications to his son's Abarth.That sounds like something that'll throw a code, weird that it didn't in an M3/M4 though. I thought it would considering how crazy the electronics are in those things. Maybe someone can take a crack at it and see what happens... worst case scenario you could just plug in a scanner and clear the code no?
[email protected] was able to accomplish this, here is what he shared with me:With the M3/M4 you can select "Sport Plus" mode which will open the exhaust valve and then you can go underneath the car and unplug the exhaust valve harnesses on each side and tape up the connector to protect them. Granted this keeps the exhaust valves open and at their loudest all the time but you can plug it back in when you want and this requires no modifications whatsoever. This was known as the "golf tee mod".
So with the QV, can you select race mode to open the valve, unplug the harnesses if they are accessible and keep the exhaust loud all the time without throwing an error code? If possible, this is what I will likely do unless I look at an aftermarket option like Novitec, Akrapovic, etc
right now maybe the easiest way to do so is zip tie the vacuum switch open.Is anyone offering an aftermarket method for keeping the exhaust by-pass open or closed at the driver's discretion? I'm ready!
http://www.giuliaforums.com/forum/5...qv-exhaust-modification-race-mode-active.htmlright now maybe the easiest way to do so is zip tie the vacuum switch open.
You dont need new valves but only some actuator like thisJust notice there r some remote control vacuum setup available on eBay like this
https://www.ebay.com/itm/252720425002
I talked to my mechanic he said we can try it. But I need to get my car delivered first!
The exhaust valve is vacuum controlled. Should have it figured out before we get too far along. Some of the issue with these cars is the underbody tray requires a bit more time to carefully remove.
Tech info with diagrams and so forth is a ways off for the enthusiasts. Though, hopeful we can find the vacuum source in the engine compartment and create a separate mode switch that does not require any underbody work (where the actual exhaust valve is located).
Unplug vacuum hose and insert screw. No code cure yetIt's entirely possible that it is codeable.
Is there anything like this available for the giulia 2.0ti? I just took my rear apart and couldn't find any valve to do the golf tee mod :/ I really don't want to have to install a different exhaust system.. here are some pics of the undersideright now maybe the easiest way to do so is zip tie the vacuum switch open.
