Hey all,
A weird problem popped up this weekend as I neared the end of a 5hr drive down to Ohio. I’d been cruising along a two-lane at about 55mph when I came to stop sign. When I was ready to proceed, I pushed the throttle pedal and the engine didn’t respond. I looked down and saw the Service Electronic Throttle warning and that the engine was still running, just at idle or near idle speed. With cars behind me, I gave it full throttle and crept my way to the shoulder.
I shut down the car and restarted it; it fired right up, no MILs. However, when I tapped the throttle— still in Park— the revs continued to build after I lifted my foot. I waited a sec as they went up to 3k, at which point I turned the car off.
Confused, I pulled my OBD reader; no active or stored codes. Weird.
I decided to restart the engine and got the same raising revs issue when blipping the gas in Park. The revs built quickly with no sign of letup, so I shut the car down at about 3k rpm again.
Being in the boonies near the WV and KY borders of OH, I figured since it idled normally at startup, that I’d try to select Drive before hitting the gas, and to my surprise I was able to then give it gas, drive a few feet, then brake to a stop without the revs building. I decided to carry on the few miles to my destination, and arrived there without problem, however, when I put it in Park, the revs ran loose again.
I left the car sit for two days, figuring I would try to drive the nearly 2hrs towards Cincinnati, where there’s a dealer, and whether I made it or not, I’d be closer to the dealer and to civilization. Well, when we pulled out this morning, the car seemed fine and I decided to head towards Dayton instead, because it was more on the way home.
I wound up driving nonstop 4.5hrs, almost the entire way back, without any sign of trouble. When I did stop for gas, no problem. When I got to town, I stopped at the bank ATM and when I put it in Park, revs surged.
So I’m home, and planning to call the dealership for an appointment tomorrow, but I wonder if anyone has any idea what would cause such behavior? I do have an AFE airbox and dry cone filter on it, but this seems an electronic issue, particlarly considering also how the throttle MIL vanished without a trace. Thoughts?
