1 - 15 of 15 Posts
Is it normal to hear a loud ticking noise (assume is valves) when cold? Referring to the quad V6 engine. It seems that is getting louder or it could just be me. 3200 miles.
You mean when the engine is cold while idling? The ticking noise is probably the main control solenoid on the high-pressure fuel pump. Ticking noises are normal in a direct injection engine.
Very cool video! its crazy how quickly the injectors spray gasoline. But I don't think you can compare the sound from the video clip to a fully assembled idling engine. The injectors will be within the engine block and will clicking noise will sound different.
Well, it is possible and close. However, the noise goes away when the engine warms up. If it is the injectors then I would think it makes the noise all the time (in my non mechanical mind).
Seems logical. Is it cooler in the mornings now where you live? Sometimes that's all it takes.
Giulia not a morning person?
I am trying to find the thread on it, but I thought we all aligned on the ticking noise coming from the passenger side of the engine (at least on US cars) being a result of the engineering differences that bank uses due to cylinder deactivation. Certainly could be wrong here, but that's the only place I've heard ticking on at least four different QVs. This is not to be confused with "pulsing" that is heard from the injectors.
1 - 15 of 15 Posts
