Just keep in mind that they DO NOT circulate oil after engine shut down, and that's the issue. The turbo can spin up around 3000 revolutions per SECOND at full throttle. If you do that and then shut the engine off moments later, it's likely that the turbo will still be spinning pretty fast, and without oil pressure, bearing life will suffer. Of course if you drive it gently, or even normally for a couple mins before shut down, the turbo will have time to drop to idle speed and the oil pressure drop won't be a factor.As mentioned above, it's pretty common for turbo cars to circulate coolant/run fan operation electronically for a period of time even after engine is shut off. Good peace of mind.
If you want to do your best to increase longevity and reduce incidence of problems, for ANY internal combustion engine, it is best to allow a moment or two of idling before you shut off your engine, after it has been in use. For example, even my Cub Cadet lawn mower (with Kawasaki gas engine) states in the owner's manual that one should allow a full minute at idle, before shut off, after use. This is even more important for turbo engines, especially after arduous use such as spirited road driving, or track events.Just keep in mind that they DO NOT circulate oil after engine shut down, and that's the issue. The turbo can spin up around 3000 revolutions per SECOND at full throttle. If you do that and then shut the engine off moments later, it's likely that the turbo will still be spinning pretty fast, and without oil pressure, bearing life will suffer. Of course if you drive it gently, or even normally for a couple mins before shut down, the turbo will have time to drop to idle speed and the oil pressure drop won't be a factor.
Normally in real world use, you will typically go through a parking lot, or neighborhood before shutting off the car, that sort of forces you to let the turbo slow down a little, and after shut down, the coolant pump will do the rest, so this isn't really much of an issue.
Greg
