I'm impatient and couldn't wait any longer for the aftermarket to release a performance intake setup for our cars. So I made my own by just replacing the stock box with a K&N cone filter. Pics below if anybody is interested in doing the same. The result is some muted but more apparent turbo noise which is worth the $36 I spent.
7mm socket
10mm socket
4mm hex key
3.5" cone filter
2+ Peronis
1. Loosen the bolts to airbox x4
http://www.giuliaforums.com/forum/attachment.php?attachmentid=27289&thumb=1
2. Remove the 2 hex bolts holding box to MAF
http://www.giuliaforums.com/forum/attachment.php?attachmentid=27297&thumb=1
3. Remove the air filter
http://www.giuliaforums.com/forum/attachment.php?attachmentid=27305&thumb=1
4. Remove the bottom of the box. Undo the 10mm bolt pictured then tug up on the box.
http://www.giuliaforums.com/forum/attachment.php?attachmentid=27313&thumb=1
5. The lower ait box is held in by two rubber gromets. Watch for the air tube directing fresh air in that attaches to the side.
http://www.giuliaforums.com/forum/attachment.php?attachmentid=27321&thumb=1
6. The fresh air tube detaches by pushing in on the tabs on either side. I left mine in the car for more air flow.
http://www.giuliaforums.com/forum/attachment.php?attachmentid=27329&thumb=1
7. Install the new cone filter on the end of the MAF.
http://www.giuliaforums.com/forum/attachment.php?attachmentid=27337&thumb=1
8. Enjoy those Peronis!
7mm socket
10mm socket
4mm hex key
3.5" cone filter
2+ Peronis
