1 - 20 of 49 Posts
Hey all, any thoughts are appreciated. Two days ago gave my Ti Sport a hand wash. I had the FOB in my pocket and while drying I could hear the doors lock and unlock multiple times.. When I approached they'd unlock; when I stepped back they'd lock. Multiple times. My guess is 20X..
Yesterday no driving. Tonight I went to fire her up and completely dead.. Had to use the key inside the FOB for entry, and there is no sign of life whatsoever from the console or dash. Looks like the battery is completely drained. Curious if anyone knows of any secret codes in terms of "pump the brakes 3X and gas 2X" in order to get the car to wake up. I doubt the battery is really dead.. Instead I lean to the car shut itself down due to all the lock/unlock sequences.
Thanks,
Bruce
You might disconnect the negative battery cable and reconnect. Listen for any resets in doorlocks or such. Try again. If no life then hook up to a battery tender and look for signs of life. Still no luck, may be new battery time.
Thanks,
Bruce
Try a voltmeter across the battery leads or the under hood jump start terminals? That will positively indicate if the battery is dead.
A 12V test lamp is not as accurate, but will also get the job done.
A battery tender will take days to charge up the battery in Giulia from dead. A charger that can supply at least a couple of amps a better plan, assuming that the battery is dead.
I haven't experienced exactly your issue but have suffered a dead battery when I left a Bluetooth ELM327 OBD2 diagnostic module connected to the OBD port (UK/European car) overnight which killed the battery. My car did unlock itself a couple of times on its own and the alarm went off a few times early in the morning as a result of battery slowly draining. When I went to start the car in the morning it would not unlock so had to use the keyfob key to get in followed by dead dash and console. Yours surely sounds like a dead battery. I don't believe there is any secret wake up sequence.
I ended up jump starting the Giulia using another car at the jump terminals under the hood after leaving the donor car battery connected for about 10 mins with engine running for batteries to equalise before attempting to start the Giulia. There were a number of Check Error codes on first start. The battery also has IBS (Intelligent Battery Sensor) which will need to go through a re-learning phase of about 4 to 5 start/drive cycles over 40-50mph (I think). While IBS is re-learning Start-Stop system will not work (if fitted in the USA am not sure). I could clear the other codes using the very OBD2 reader that caused the battery to go flat :D . The car may also remain in N mode without full DNA modes until all errors either self-clear or cleared by diagnostics.
You are probably better off calling AR breakdown assistance if you guys have such an arrangement. Ultimately, AR need to diagnose what caused the battery to drain which from your description sure sounds like either door lock or key fob related. If you have what is called over here as "Convenience Pack" to allow keyless unlock/lock of doors which has a button + hand sensors on the front door handles these could be faulty or stuck causing repeated door locking/unlocking.
Hope this helps.
My TI does the locking and unlocking too when standing away and spraying with hose or hand washing the doors. I asked service and they said not to have key in pocket when washing. I think it's the sensors on the door handles, the water tricks it to think it's a hand and the logic sees a key. The sensor is probably looking for a change in resistance.
PS I hope the door handle buttons are water prof.
I have washed my car plenty of times with a car safe pressure washer and the lock buttons do appear waterproof. I always leave the keyfob away from car when washing to stop it unlocking every time the sensors detect water and assume it to be hand. Still does not explain why the OP's battery drained.
Sorry to kick this post back to life but need to whine to someone.. I had a dead battery yesterday and had to resort to calling for Alfa rescuers which involved just a phone call to get a wrecker to my home.
I took the car to a car wash the day before and pressure washed the tires and wheels and ran the car thru a touch less auto washer. Wiped it all down with detailer and parked it in the garage..
Got up yesterday to a completely dead car. had to access the trunk latch inside to get to the battery and tried my trickle charger but the lights in the door handles began to flash and click. Freaky... so I waited till the wrecker came and he jumped it using the posts in the engine department. Started up ok and began cycling through all of the codes and engine service bells and whistles.
Drove it around a bit and after a few minutes it would start and run ok but the warnings continued to cycle. Loaded it on the flatbed and said see you later...called the dealer to let them know it was coming.
Dealer service tech has been on the phone with me and the car is being evaluated, no idea what may have caused this so far,, not home to me yet ..
The real positive part of this is this experience is the response from the Alfa Roadside Service folks. I made one call gave my name and they had my phone number, address and details about the car and they took me serious and sent a service wrecker as soon as able. In addition they called me four times to check on my status to determine if there was anything else they could do to aid me. Great to know Alfa is standing behind their product and reputation.
Film at 11...
Film at 11...
We understand how this could be frustrating and are glad that your Roadside service was able to accommodate you in a timely manner. We would like to offer an additional layer of assistance while you are working with your dealer, and look into this further for you. Please send us a private message with additional details.
Julie
A little point of concern about the battery. I was on the phone with AR-USA the other day about a different issue. Without any prompting, the AR-USA guy says that if the car is parked in cold weather, it needs to be connected to a trickle charger or it will drain down. Huh?
This doesn't affect me much because I live in Texas, but what's going on for AR-USA to give out this unsolicited instruction?
Thankfully my PLX Devices Kiwi3 automatically goes to sleep after a period of inactivity and only has 3.9mA power consumption in sleep mode. Assuming the battery is healthy to begin with, one can leave the car parked for weeks on end with the OBD2 module connected without an issue.
The batteries have been problematic in cold weather, I’ve seen it several times now and it’s quite frustrating since it causes funny issues. FCA is now aware and likely throwing it out there to reduce chances of complaints, in your case it’s irrelevant but the batteries are a problem in my area. The replacement batteries we use are Chrysler tagged, so maybe they’re different (better?) than the AR ones.
I believe that the core issue is that the batteries have a special chemistry to support the cursed start-stop function.
FWIW: an 80AH battery can supply 238mA for 2 weeks. After 1 week at that draw the battery is likely to not be able to start the car.
It is not obvious how much standby current the functions built into the car draw, but it is certainly more than 0. It is possible that this draw is larger at lower temperatures, although most silicon devices draw less power at lower temperatures.
They’re probably designed to withstand colder temps. I guess Germany (Varta battery) is not as cold as Canada
2017 Ti Q2
The other day, I had the same problem with a dead battery. I'm planning to take my car to the dealer. I will report back with what they say.
Harold
2017 Ti Q2
Earlier this week, I charged the battery and was able to come and go. Today, I drove the car to the dealer and described the situation. To make a long story short, they wanted to keep it at the shop until a new battery arrives from Michigan, which should take a "couple of days." Although they said the battery was completely dead, somehow the car started and I drove it home.
I also had them look at the passenger seat, which sometimes does not slide backwards. Since they could not repeat this issue, it will have to be looked at sometime in the future.
More to come.
Thanks,
Bruce
I'm dealing with the same problem right now (washed the car yesterday with key fob in my pocket). What did you end up doing to get it resolved?
Guys, stop washing your car with the fob in your pocket; I just leave it in the car. Also, there is a place in settings that you can turn off the option of the car automatically unlocking when it senses the fob near the handle.
Is it possible to drain the battery that much from just lock and unlocking? Prior to me washing the car, I had driven 150 miles so I think the car should theoretically have been on full charge.
2017 Ti Q2
Tomorrow will be day 9 waiting for a battery from the dealer. The wait has gone from a couple of days to a week and a couple of days.
Hello All,
New to the Giulia forums, and seems I have a similar issue.
I have a Giulia QV, which sadly has to go into storage for the MI winter, and the battery went dead on me. Been trying to recharge it direct to the battery, per the owner's manual, but won't take a charge. Jumping It gets the electrical system up for a few seconds, but won't get the engine to turn over. So, I'm equal parts baffled and pissed off. Any ideas for what I could potentially do to get mobile again?
I appreciate any help anyone can give.
Cheers,
Chris
1 - 20 of 49 Posts
