Dark Granite Giulia is GORGEOUS
4381 Views 10 Replies 4 Participants Last post by  Vinales
6
I know I just said I was in love with the blue... but that was before i saw the granite... OMG... the sparkles ;)
See less See more
1 - 11 of 11 Posts
Not a big fan of the glitter when it comes to basic colors. At least not that kind of sparkle. Is this going to be the Giulia's paint trend?
I think that there is a bit too much sparkle going on. I like it to be more metallic shiny than glittery.
you know that only how it looks under hyper bright show lights... also the photogs settings play a factor... was he looking to play up the metallic bitS??
this one offers a good look at it in direct and not so direct light...
See less See more
That could just be due to the intensity of the lighting at the show, Seeing it in person will give you a better idea of what to expect if you were to own one.
I'll reserve my judgement till I see some more pictures I suppose.
3
MT has some good photos of Granite... I wonder if its a glass flake under there... the depth and sheen are IMPECCABLE!
See less See more
Looking at the following picture i'm starting to think i might need a small spacer to push the rear wheels out a bit, maybe even the front for a bit more of a flush look :D
See less See more
You never know, it might already have spacers. I know Porsche has a habit of using wheel spacers from the factory.
I wouldn't put it past Alfa, this platform is supposed to have more pedestrian uses, I could see them using spacers to get the desired track instead of making significant structural revisions...
Valid point about track since it's much easier to use spacers than it is to design things around building up to what is ideal which can way too specific, costly and time consuming.
Regardless, I think the gap you were seeing above is because the wheel is ever so slightly turned, leaving the illusion of space... IMO...
1 - 11 of 11 Posts
