21 - 40 of 45 Posts
I have also tried the washer under the seat rail method, but my seat rail developed an annoying creak. No matter how I tried tightening the bolts the issue kept coming back and I was forced to revert back to the factory configuration. So personally I will not mess with the rails anymore. I wish there would be a way to achieve a seat tilt without modifying the seat rails.
Supporting Vendor
Discussion Starter · #22 ·
RE: Stelvio Fitting
I hope you guys are right as I'd like a "clean" solution- but when I compare the pic of the rail Centerline posted, and the pic of the rail I have, am I missing something here?
The rail used for photography was from a set of Giulia QV Sparco seats - they look different but fit into the same floor contours as the standard Giulia seats.
2018 Stelvio Sport Q4 Nor-Cal PRK
^^^^^ Guess we'll find out Friday when Alfatrooper visits your shop.
I'm in if it will fit a 2018 Stelvio Sport
Would also be nice to see it it as an option for the Passenger side.
Don't want to hear any "what about my side" comments from Mrs. Fast. :cool:
Administrator
It's the same left to right. Buy two sets.
@JoeCab, the Centerline site says base and sport seats. What about Lusso seats?
Administrator
I can't imagine they would have different mounting for the different seats. The floor boards are all the same.
I think the Lusso seats already have the tilt feature at the begin with. Probably that's why they are not listed.
They do. Or at least they did in my 2017.
Supporting Vendor
Discussion Starter · #29 ·
Right.
I guess if you wanted MORE tilt, there would be no reason you couldn't install these on Lusso seats, or QV "Comfort" seats that already have the electric tilt feature built into the seat base.
2020 Giulia TI
Just installed these. Took about 15 minutes, including time to find the Torx. Short test drive tells me these are a great idea. I have the base TI seats and these give some much needed thigh support that wasn't available before. Thanks to Centerline for designing these!
Reactions: JoeCab
2020 Giulia TI
Update. Had a 2 hour drive today. New angle of the seat is very comfortable. I'm 5'10 and my thighs were always slightly unsupported with the stock tilt. Now they actually rest on the seat, although I would still like to have the cushion about an inch longer. My opinion, others may disagree.
2018 Stelvio Ti Montecarlo Blue
So, update on the seat rails in the Stelvio and on the passenger side.
Took a drive up to Centerline today and met up with Joe for a test fit on the Stelvio.
He was ready for me with the kit and the needed tools.
Short answer, it fits great on the Stelvio driver's and passenger seats.
Here is what comes in the box.
112026
The stock bolts are T-50 torx head,
The new bolts for the front are 8mm hex.
Slide the seat all the way forward and raise it up . Loosen but don't remove rear bolts.
Slide the seat all the way back.
Remove the front bolts.
The weight of the seat will likely raise the front of the rails.
112027
Fit the adaptor under the rails
112028
Set both of the adaptors in place before putting the new bolts in.
112029
Tighten the top bolts
112030
Slide the seat forward and tighten up front bolts.
Spec for tightening the seat bolts is 30 ft pounds
All done....
112031
Looks great and noticed a big improvement in comfort for me.
We grabbed another set and tried the passenger side.
It installed just as easy and fit just as cleanly on the passenger side.
Just FYI, here is a shot of the top of the passenger rail showing the stock T-50 head bolt.
112035
Thanks @JoeCab for continually adding great new products and for being just an all around Great guy!
Parting shot of Joe's Giulia, so sweet!
112036
Joe was right -- even I, the man with 10 thumbs, could install in under 15 mins (including Blue threadlock compound). Will test it with a drive to Dillon and back tomorrow.
Also awesome to meet Alfatrooper at Centerline today. He's got the Alfa flu real bad, and that's good! Great posting above, too. 👍
On a peripheral subject: is there a reasonable way to clean out the dirt trap that is formed by the side of the seat and seat rail and the sill? My narrowest vacuum cleaner tool will not fit in the gap. Is lifting up the rail going to make it even harder to clean out?
Any additional feedback after months of use? Any squeaks or something else?
About a month in, no issues or noise. Quality made product. 6'0 here about 180lbs.
2018 Giulia Ti
Just did a 350 mile day trip and it’s a great improvement. I’ve had them installed 5-6 months
Meant to post this much earlier, but got distracted by work (Grrrr....) and a broken leg:
Did a 3,000+ mile trip to SF and wine country in June/July, with a 3 week stayover in Brisbane, CA. Had mucho seat time with the Centerline Seat Tilt Kit and have to confirm that the driving position is "just right" and my comfort was maximal. Did the 1,240 mile to and from Brisbane in 2 days each way and 9 hours in seat per day had me feeling fine with the more relaxed and "bucketed" position in the Sport seat.
Only negative comment is with the AR rail mechanism, which at certain distances fore-and-aft, gets a slight creak. Strangely, adjustment just a tap forward or backward cures it instantly. Strange.
Was about to match the driver's side with a passenger side purchase, but until I heal a bit, can't do the installation. Will buy another in the next few days, after my doctor clears me to crawl around and turn wrenches.
Again, another great Alfa enhancement from Joe and EC!
MTB
P.S. The new driving position works great with a left foot (yeah, the only good break I got) fracture boot on and getting in an out with crutches is no big deal, which is a bonus. Man gotta drive!
Reactions: Glenn
MTB
Oh, man! Sorry to hear.
Hope you continue to heal quickly
21 - 40 of 45 Posts
