1 - 17 of 17 Posts
Ok day #3 with the car and the brake shrill at low speed when coming to a stop is unbearable. I saw a small child on the sidewalk nearly fall over being startled and cars in front of me creep forward giving me an extra 5 feet (of course I don't dare release the brake to creep forward as well). This awkwardness is truly ridiculous. I figure it is a Brembo thing on the QV. I inspected and have nylon backers. I could just remove pads and re-grease but if I'm in there I figure a replacement pad is probably worth the effort. So.....has anyone a good brand recommendation for this car? Goal: daily driver, no autocross, no squeeking, low dust if possible, would be nice to keep a high performance pad in there for the sake of what the car is. Thanks!
Mine squeal when cold, warm them up with a couple of brisk brake pedal application and it goes away.....
Yes, and it comes back when the rotors cool. Which is exactly what happens in city traffic when it is most embarrassing! I suggest Centric, Posiquiet ceramic pads. AFAIK, Maserati GT, Lexus ISF pads will fit from the mid to late 2000s. Here are the specs I have so far.
Fronts:
164.7x81x55
Pagid no. 8005
2013 Ghibli 360mm disc
2007+ Gran Turismo
2011 Lexis IS-F
caliper hp 6 165x82
Not sure of the rears.
I have standard brakes not carbon ceramics. It was slightly better today - maybe it will abate. I plan on waiting a week but figured a brake pad suggestion based on experience is still a valid discussion. I saw a few vendors sell EBC Yellow-stuff and Hawk brands. Not sure if anyone has experience with those. I saw the Maserati cross-list mentioned as well which helps. I've used Pagid before with good results. I didn't yet see a post about Pagids until John K's above. I know the car is new so probably noone has gotten enough mileage up to need a change unless needed for racing but then I don't really want racing pads or I might be back in the same boat. Thanks!
Ok I'm still in a quandry but in looking at Pagid's website I can confirm the front brakes on the QV is shape 8005. The rears are shape 2487. This means the front pads are interchangeable (and also spec'd for) with Lexus IS-F 2008-11, Maserati Gran Turismo 2007-present, Ghibli 2013-present, Mercedes SLK (R171) 55AMG 2004-11, Subaru STI with 6 piston Brenbros 2017-present. The rears are compatible with a huge number of cars (not all listed here): Aston Martin DB9, Aston Martin Vantage GT4 2012-present, Audi RS3 2011-12, Audi TT RS 2.5 2009-14, Chevy Camaro SS 2009-15, Corvette C7 2014-present, Dodge Viper SRT 2014-present, Ford Mustang GT 2015-present, Shelby GT500 2007-14, Acura TL 2004-present, Hyundai Genesis 3.8 Coupe, 2010-present, Maserati Ghibli 2013-present, Mitsubishi Lancer 98-2016, Subaru STI 2003-16, Volvo S60 Turbo R 2003-present, Volvo V70R 2003-present.
Please double check in case the list is incorrect as I have not verified the above but hopefully this helps for the future.
My OEM pads went through a period of squeeling but it only lasted a few thousand miles. I recently replaced them with EBC yellow stuff and they are now squeeling so I wouldn't go down that route.
Mine have been quiet for several months. I checked Tire Rack for the Posi Quiet Ceramics on a Subaru-Hyundai combo. $40 for fronts, and $40 for rears. Awesome value and even though my brakes have been quiet, the dust is notable. Washed the car 2 weeks ago and my bright fronts look like darks.
Hey buddy. How sure are you with the rears? The front is spot on Crosses with Ferrari 599GTB
Just ordered EBC blue for front and was trying to find blue or yellow for rear.....
Would it cross with the Ford Mustang GT standard or performance brake. EBC has diff numbers
Thanks,
I recently did the front and rear brakes on my QV steel brakes.
Girodisc floating rotors front and back
HAWK HPS pads on the front and POSI-QUIET semi metalic pads on the rear. Posi quiet was out of stock for the fronts.
In my opinion they are much better than OEM setup.... very quiet, much less brake dust and I find the brakes not as grabby when coming to a stop, much better feel.
The giro disc rotors are slotted not drilled and for the next brake job you only need to replace the outer ring (much cheaper) as its a two piece setup.
Up here in Toronto the whole job, parts and labor was $3,600 taxes in and the dealer quoted me about $4,500 plus tax for OEM.
I believe this setup is superior to OEM.
I agree you should be good for a while with this setup. I debated going with the Girodisc but decided against it as the factory discs are available for the same price from Alfissimo as for just the Girodisc rings, so there's no advantage other than slotted vs drilled.
Alfissimo is a great option however I live in Canada so the exchange rate and duties make it hard to justify ordering from them.
1 - 17 of 17 Posts
