That code is “Fluid Leak or Seal Failure. this sub type is used for failures where the control module detects that a mechanical component has an unexpected gas or liquid flow in, out, or through the component.”
I suggest that you try bleeding that brake caliper to get any air out. Reset the code with MES and see if it stays cleared.
