I’m really liking the device, but there is no good/hidden space to stow it. I’m also not a big fan of the LEDs glaring with it stashed between the seat and console. I like to keep add-ons/installs as close to OEM looking as potentially possible (it’s just a pet peeve of mine).
So I printed a small holder/mount for my BMS Pedal Tuner. It’s installed into the cubby; lower left of the US steering wheel. Thought I’d share.
So far so good - there’s not a lot of spare cable after it’s been run this far but it works. I pulled the cubby, cut a small hole in the upper back to feed the controller thru, then bolted the printed mount to the (inner) top of the cubby. It’s positioned so that the latch enclosure on the cubby door actually holds the controller in place when the door is closed. Here are some pics of the install:
