I'm planning an update to my Giulia's base audio system. I'm going to do it as a DIY and I chose the least complicated solution as it will be my first car audio system install.
For that I purchased an Audison AP5.9bit 5 channel amp with a DSP and all the necessary Audison Prima wiring harnesses to make it pretty much a plug-and-play affair.
The only wiring I'd have to add is speaker cables to the front and rear tweeters in case I decide to make the system full active or use components.
And here lies the complication – because of the peculiar positioning of the B-pillar in the Giulia in combination with my driving position and the suboptimal front tweeter placement, I seem to be getting most of my high frequencies not from the front tweeters but from the rear ones. My simple logic tells me that I should then focus on the rear tweeters more than on the front ones while replacing the speakers and configuring the DSP.
However, the overall consensus regarding stereo upgrades seems to be that the main emphasis should go to the front (by installing either component speakers or going full active) and the rear could be left either untouched or coaxial speakers will do the job just fine.
So, the question is whether I should do:
How have your dealt with this and how do you defend your decisions? Have you been able to get sufficient high frequency reproduction from just the front?
I attached some options from the AP5.9bit's manual.
- the regular "expert recommended" install:
- separate tweeters / midbass at the front (either component or full active) and coaxials at the back; or
- should I take into account the Giulia's specifics, my current experience and put emphasis on the rear tweeters as well
- meaning component speakers both at the front and rear.
