1 - 20 of 24 Posts
I was thinking about how most of the issues people are complaining about seem to be things that are addressed in software flashes.
I was hoping we could get a thread going to track what the results are.
Give us the follow:
1) Update received.
2) Date received the update.
3) Experience since the update.
Getting all these today...1/17 build. Fingers crossed! (This is the description from the dealer)
Powertrain Diagnostic/System Flash – The Malfunction Indicator Light may come on just to update the Powertrain Control Module
Radio Software Enhancements – This is concerning Radio, Bluetooth and Navigation concerns
Adaptive Cruise Control Flash – The Malfunction Indicator Light may come on for Wheel Speed Plausibility Failure and Video Camera Private Can Communication Failure
Audio System Warning Light Illuminated Updates – Audio System Warning Light will come on, Radio will turn on but with no audio sound.
I'll report back if my issues are resolved. Primary problems have been:
2 stalls a day after refueling. Both times I didn't give the car a minute to warm up before shifting to drive
Adaptive Cruise/Forward collision malfunction indicator
Nav map disappears for a second and reappears
At about the 1,800 mile mark, my car stalled and then went into limp mode with the ominous "service electronic throttle" and check engine light warnings. Prior to that it drove very hot and the engine oil temperature gauge was always at 5 bars.
I was able to drive it straight into a dealership without an appointment (not the one I bought it at). They brought it into the service area, hooked it up to a laptop and performed an "ECM flash update per bulletin 18-030-17." I was out the door and back on the road in less than an hour.
The car runs better than ever, much cooler, and the temperature never goes above 4 bars.
I have an AWD Ti with a February 2017 build date.
Infotainment Issue
I was supposed to get the Infotainment update because mine keeps randomly turning off and back on when driving. The dealership said that they have the update but cannot get it to work so I am waiting until they get it figured out.
Mine was first updated 3 weeks ago without Nav updates and was told by dealership that they I can bring it later and they will keep the update ready on a USB. It took them approximately 2 weeks to get the update ready(something about updates not downloadable or working) and then when I finally took the car last week, the update wiped out the maps completely. Since last week, they are just running diagnostics and applying patches but no resolution in sight
The update recalibrates the gauge, the car is probably running at the exact same temp.
Nope
Absolutely not. The car runs noticeably and dramatically cooler. Heat used to emanate through the hood of the car after a few minutes of driving. In fact, the day I picked it up, I commented to the salesman about how hot the engine was after we merely sat in the car with it idling while he went over the infotainment operations and other functions.
It is definitely cooler.
I agree. The engine runs cooler which I believe is how they are correcting the misfires people are experiencing. My only concern with the tech when they applied this update back in May (which I then noticed the lower engine temp) after the update, was the possibility of carbon build up over time now that the engine is running a little cooler... possibly leaner. These are direct injection engines and by design, are prone to carbon build up which can considerably rob engine performance over time. The tech didn't provide a response nor would I expect a response. But its definitely in the back of my mind. I am wondering... will my engine respond the same way... 5 years from now?
I recommend to everyone, again being that this is a direct injection engine, to once in a while slam on your accelerator... run hard through the gears and through the RPM range. Always running premium octane 91 or better fuel of course. It helps loosen any carbon deposits, if any, that may or may not have accumulated.
Thanks for this post as it creates a concern for me! I have 1700+ miles on an 8 week old base Giulia, build date 2-17, software - 001.011.020. I have only experienced several minor glitches. #1 ..... Lost my favorite radio stations setting one time only, no big deal. #2 ..... After a quick start up I put it in D and just barely moving at about 1-2 mph and it stalled with an on screen message, I restarted and no further issues, although I usually let it idle for at least 60 seconds. #3 ..... Came down a steep off ramp with a 90 degree left turn signal light at the bottom, I stepped on it to beat the red light, braked fairly hard approaching the light and then accelerated moderately thru the turn, when the engine seemed to hesitate/jerk very quickly about 4 times in 2 seconds and then continued thru the turn normally, no other occurrences of this. I thought I would just let these 3 minor issues go for some time until I found more issues before I took it in for an update.
#4 ..... I saw the previous thread about the engine temp gauge, but mistakenly thought it was just a malfunction of the gauge itself and not really high engine temp. Now reading this thread it finally dawned on me that I have noticed that the hood/engine have seemed rather warm after normal driving. I had taken a photo (see below, does this look high?) a few weeks back just to compare it to the photos on that previous thread. I'm guessing now that perhaps the engine is running hot and I should take it in to correct the engine temp as well as the other minor issues.
Thanks much for any feedback! :smile2:
Hi, based on your oil temp guage, it looks like your Giulias ECU has not been updated. Once its updated, you will see 4 bars instead of 5 when your engine is at normal operating temperature. However, dont worry about the 5 bars as that is the normal observed reading pre ECU update.
Thanks for your reply. Sorry if I'm still not clear on this. Sounds like you are saying my engine oil temp is normal at 5 bars.
ChiGuy posted earlier in this thread: Prior to that it drove very hot and the engine oil temperature gauge was always at 5 bars.
I presume the ECM update is the same as the ECU update? However you seem to indicate that the the engine oil temp is just fine, both now at 5 bars and after the update at 4 bars and only the current bar reading is off. Sounds like you and ChiGuy are not on the same wavelength.
Thanks for any clarification. :smile2:
Do it
. . . The car runs better than ever, much cooler, and the temperature never goes above 4 bars.
I think we are in fact on the same wavelength. This is not a calibration issue. The bar reading is not off. The 5 bars has been verified across this forum as an indication that your car did not receive an important update. Prior to the update, my car hit 5 bars within 10 minutes of driving. After the update, you will see a difference in the engine temperature. But more importantly, you won't be waiting for what seems to be an almost inevitable failure. I highly recommend you get the car in for the update before you have a bad experience. Luckily, I was less than 10 miles from a dealership when my car went into limp mode.
Reactions: Dr. Klopek
I'm all for getting this (and other) update(s) but from other threads my impression is that is not one you can just request and have done. I thought you have to have a problem that the dealer can verify in some way and they can then get permission to do the update. If it's just a question of whether they get paid for their time, I think I would be prepared to pay to get some of the updates done proactively rather than having to wait but I'm not sure that is an option either. For the record my Ti has been flawless to date but definitely doesn't have this update.
1 - 20 of 24 Posts
