There’s another thread on this somewhere. Last I heard, someone had one on order, but don’t think it’s been received or installed yet.Saw a 2020 looks like they added leather to the gear shift. While its still the cheap plastic, the leather def. helps the look and feel.
Anybody buy one and install yet? Here's a pic
is it just plug / play? View attachment 95404
Here's the other thread:There’s another thread on this somewhere. Last I heard, someone had one on order, but don’t think it’s been received or installed yet.
I am all in also on this. Luckily somebody somewhere will do this swap“You may be able to change just the gear selector and keep you existing bezel”
Yea, works for me. Would do this in a heartbeat, esp w the alcantara model from the new GTA. The quad mode would also work as a fallback
this fucking sucks.I just posted this in another shifter thread but thought I'd share my findings: Attempted a shifter swap (2020 to 2017) and was unable to proxi the new unit... Since the proxi failed, I was actually able to swap the circuit board from the old to the new shifter to find out the shifter itself has a different internal configuration. The car sets codes for improper gear selection in the electric shift module. I think the new 2020 cars have different resistors in the shifter which are interpreted by the new internal electronics. I don't see a way around this unfortunately.
I remember seeing in MES an option under the Gerabox/Electronic Gearshifter module (cannot remember the exact description), there is an option to learn the replacement gear shifter lever. Did you see/do that in Witech before trying the Proxi alignment? I will have a look at MES and post the screenshot.I just posted this in another shifter thread but thought I'd share my findings: Attempted a shifter swap (2020 to 2017) and was unable to proxi the new unit... Since the proxi failed, I was actually able to swap the circuit board from the old to the new shifter to find out the shifter itself has a different internal configuration. The car sets codes for improper gear selection in the electric shift module. I think the new 2020 cars have different resistors in the shifter which are interpreted by the new internal electronics. I don't see a way around this unfortunately.
In MES the lever learn is under the Gearbox rather than the Electronic shifter module. See attached. Not sure if this will work for the newer lever though as the instructions says lever should be in Neutral.I remember seeing in MES an option under the Gerabox/Electronic Gearshifter module (cannot remember the exact description), there is an option to learn the replacement gear shifter lever. Did you see/do that in Witech before trying the Proxi alignment? I will have a look at MES and post the screenshot.
I took your approach and found that on eBay you can purchase a CF shifter bezel and a small stick-on Italian flag. Total cost $25.99 + $2.99. These items might work:.....and if we could have some aftermarket vendor to create a new cover featuring the italian colors , that would also be nice .. Quick sketch to show the idea....
That Bezel is not CF. It is cheap printed ABS and not a nice look. I bought one and returned it pronto.I took your approach and found that on eBay you can purchase a CF shifter bezel and a small stick-on Italian flag. Total cost $25.99 + $2.99. These items might work:
View attachment 97644![]()
Carbon Fiber For Alfa Romeo Giulia Stelvio 2017-2019 Console Gear Shift Panel | eBay
Find many great new & used options and get the best deals for Carbon Fiber For Alfa Romeo Giulia Stelvio 2017-2019 Console Gear Shift Panel at the best online prices at eBay! Free shipping for many products!www.ebay.com
Plus: Italy Italian Flag Metal Logo Emblem Badge Car SUV Sticker Auto Motorcycle Decor | eBay
Together:
This, please!!Nothing stopping the aftermarket from redoing a 2017-2019 handle with leather, though.
Fair enough and thanks for the heads up. I didn’t order one so that’s good! I may get the little stick-on flag emblems and see if they look okay anywhere on the car. They are cheap enough so it won’t matter too much if there junk.That Bezel is not CF. It is cheap printed ABS and not a nice look. I bought one and returned it pronto.
So when I tried this it was a month ago, and thinking back through the fog, I think I mispoke about the proxi. I don't think I could actually proxi the unit(through the proxi function) and had to use a "unit replacement" function under the ESM (in WiTech). I still have the shifter but now filled with self-doubt. I will try to mess with it again. Maybe I'll try with MES. If successful, possibly re-evaulate my career choice ??. Wish me luck!In MES the lever learn is under the Gearbox rather than the Electronic shifter module. See attached. Not sure if this will work for the newer lever though as the instructions says lever should be in Neutral.
View attachment 97642 View attachment 97643
