1 - 7 of 7 Posts
Every single one of my check engine lights are on.... it keeps rotating through every fault on the gauge cluster. Drove fine, went into the store came out and started it, now this.
Service power steering
Service dampers
Service ESC
Sound system unavailable
Auto high beam unavailable
Service hill hold control
Service ATV system
AST service required
No tech on duty to answer my questions.
Service dampers
Service ESC
Service ATV system
Sounds like something in my RR. Turn the car off, wait, and turn it back on? I can pretty much guarantee you you have none of those problems...just wonky electronics...clear all the fault codes if they stick around (OBD II reader)
This, and the OBDII reader is the proper way to clear codes. If you don't have one and it persists, Disconnect the negative terminal on the battery and reconnect. You will have to reset all you radio stuff.
Possible issues:
Best Case:
-Software Fault
-Mis-calibrated throttle-body/Glitch
-Battery Faulty (low Voltage)
-ECU Failure/Fault
Worst Case:
-Bad Wiring Harness
1 - 7 of 7 Posts
