Sorry, correct term is corner balancing. Driver must be inside, but I'm not sure about how much fuel should be there - perhaps 50%?
Sorry, correct term is corner balancing. Driver must be inside, but I'm not sure about how much fuel should be there - perhaps 50%?If you did a weight balance, would you account for a driver? What about the gas tank?
I drove a bit yesterday and Sunday to test them out.I find that you have to drive the car for the springs to settle. Have you done this already?
Springs don't settle....I find that you have to drive the car for the springs to settle. Have you done this already?
Would love your review on these vs ST... I'm contemplating doing the same... How's the stance? Any pix for after? I love how the car looks on STs... would love a higher spring rate to help avoid the occasional bottoming out in the front.I drove a bit yesterday and Sunday to test them out.
I'll give it some more time.
Correct. Most springs vary a little. You can check out here the differences in heights with cars. So many variables too.Unless you decide to make spring spacers it is something you cannot change, so I would just let it go and leave it as it is. On cars with adjustable spring height you can also perform weight balacing, but apart from KW CDDC there are no such springs available for the Giulia. GMS is colaborating with Nitron to develop coilovers for the QV in the forseeable future.
I've thought of something.Springs don't settle....
Busting the "Suspension Settling" Myth
For years I’ve heard lots of talk of springs “settling” after install. As a mechanical engineer, I’ve always been skeptical. Springs won’t “creep” or sag after a few miles of driving on them. That just doesn’t make any sense. Creep in steel is a long term phenomenon and is a concern only in...www.giuliaforums.com
Yes, springs more accurately the suspension do settle and end up slightly lower then when initially installed. FACT.Springs don't settle....
Didn't observe that with ST Springs and Alfissimo GTA springs.Yes, springs more accurately the suspension do settle and end up slightly lower then when initially installed. FACT.
My data doesn't support your "fact".Yes, springs more accurately the suspension do settle and end up slightly lower then when initially installed. FACT.
Monitor this thread.Would love your review on these vs ST... I'm contemplating doing the same... How's the stance? Any pix for after? I love how the car looks on STs... would love a higher spring rate to help avoid the occasional bottoming out in the front.
I also posted many photos and review of different spring setups and CDCM softwares... If you'd like to check them out.Would love your review on these vs ST... I'm contemplating doing the same... How's the stance? Any pix for after? I love how the car looks on STs... would love a higher spring rate to help avoid the occasional bottoming out in the front.
I installed ST springs and the car ended up lower about .5cm after some normal driving.Didn't observe that with ST Springs and Alfissimo GTA springs.
I definitely observed this when I started racing on my ST springs. My car was practically slammed before removing them.I installed ST springs and the car ended up lower about .5cm after some normal driving.
OK. Regardless of the recent discussions here, my installation DOES seem to be settling. Again, I suspect it's due to the springs fully settling into their perches.... not spring-sag which wouldn't make sense to me.Would love your review on these vs ST... I'm contemplating doing the same... How's the stance? Any pix for after? I love how the car looks on STs... would love a higher spring rate to help avoid the occasional bottoming out in the front.
Is that at Scuderia 110 with Hari?Just dropped my car off for install of the GTA springs and GMS camber kit. Gotta get her a little lower for those John4c wheels!
👍Is that at Scuderia 110 with Hari?
Thanks for that man. Whenever she’s not in my presence I worry a little!It is in good hands.
It is Harri is the best. Period. Excited to hear Harri's feedback.It is in good hands.
