Today is a very special day as we get to let you see what we at MADNESS have spent the last six months working on!
The very first custom made direct factory replacement full carbon fiber intake box!
We just fitted the final prototype to our Giulia and the final version should be available to order in the next 30 to 45 days!
The box completely replaces the original factory box and houses an entirely new filter. The filter has been upgraded from a flat panel to a large diameter double cone. Shown here from left to right is a factory filter, a drop in BMC filter, and the new double cone filter.
Which is then completely enclosed in the carbon box allowing it to scoop cold air from the intake tubing and not the hot air in the engine bay. This also helps to keep the filter cleaner longer and add the custom look under the hood.
Has you can see, the new box is much smoother than the factory one which allows the engine to breathe easier and increase power.
We also did not move or relocate any of the sensors. The mass air flow is still in the original location, orientation and order. So we have not seen any errors or check engine lights as a result of this upgrade.
We are also working on replacement tubing after the MAF. That tubing will also have a smooth design and constructed out of silicone. It should also be available within 30 to 45 days has either a separate piece or in a kit with the carbon fiber box.
