Hello!
I recently bought a 2018 Alfa Romeo Giulia Veloce Q4 2.2 JTD, and even though this is my 3rd Alfa Romeo (166, Giulietta and now Giulia), it is my first Automatic and first AWD, so I started doing a little research to know what I'm driving a little better and eventually got to the fluids.
Besides the common fluids like engine oil, engine coolant and brake fluid that all variants have, I was told at the dealership the AT8 Q4 additional fluids are considered to be "lifetime filling" by Alfa Romeo. These are, as far as I know:
I guess the last one is also present in all variants, but my point here is the "lifetime filling". I know these oils don't have combustion contamination like engine oil, but the mechanical wear in my mind should be reason enough to change them. Maybe not as often, but still...
As for the gearbox specifically, according to my research, in order to change the filter along with the oil, I would have to replace the gearbox oil sump as well. Is that right?
So I wanted to ask the community for some advice on this. I imagine that normally, if any owner takes their Giulia to the annual car service, the dealership would not change any of these unless explicitly asked to. Is this something I should ask? If so, how often? Is there any risk involved?
Feel free to share any information you find useful. Thank you!
(Edit: just noticed a section named "Oils, Fluids, Fuel, Additives And Lubrications", I should've created this thread there, sorry. If any moderator can move it, please do)
- Automatic transmission (Petronas Tutela Transmission AS8 ZF TE-ML 11)
- Transfer case (Petronas Tutela Transmission Transfer Case 75W)
- Front differential (Petronas Tutela Transmission Hypoide Gear Oil 75W-80)
- Rear differential (Petronas Tutela Transmission LS Axle Fluid 75W-80)
