1 - 19 of 19 Posts
Nice!
So the heat control switch is on the seat frame, not on the center console?
Yes on the seat frame not on the dash.
Is this like a rocker switch? Hard to tell from the pic but it would be tough to know which setting you are in with push button...
I guess that means that base Giulia doesnt have the neccesary cabling for the switch and position indication in the harness? Certainly interesting solution
It is a rocker switch.
The middle is off and the bottom is low and the top is high.
Only two levels.
From a dealer install, it came out perfect.
I'm surprised that's not standard across the board.
Supporting Vendor
This is a clean install.
I would have never thought to locate the switch on the seat surround, but it makes perfect sense once you know it's there.
how much did you end up paying? I have mine included but never used them!
$400 installed I believe.
Are yours also dealer installed?
The great thing is my dealer even said since I got them installed when I bought the new car that it would be covered under my standard and extended warranty.
Discussion Starter · #13 ·
This is awesome! Do you know what company the dealership used? What dealer did you buy from?
Not sure who the company that the dealer used, but the dealer that I purchased it from was Fullerton Alfa Romeo in Somerville, NJ.
A few cars ago I had aftermarket leather seat covers installed and included heaters for about $100 more, they used this exact kind of switch. Those are nice because if you turn it on it will still be on the next time you start the car.
Thanks!! Is this both seat bottom and back?
Discussion Starter · #16 ·
Only front.
Do the 2021 models have rear heated seats now?
Only front.
As part of a $2300 premium package that includes the HK stereo upgrade and a few other items.
rear heated seats have been available as part of some package for a bit.
Only front.
1 - 19 of 19 Posts
