YOu can do it, and it's not as crazy as you think.
You can get the paddles and associated column trim from ebay, or even an AR vendor.
In order to white to the ECM, you need a Security Gateway Module bypass (SGM bypass), a usb obd2 adapter, blue and greay adapter cables, and multiecuscan (MES). Alfissimo International sells a kit. If you search the site, you should be able to find a write up.
Welcome!!
Welcome!!
