1 - 8 of 8 Posts
So I am going to pick up a set of five holes down the road when my stock tires wear out. I see sets being sold as replicas on Car ID and ebay that are 19x8.5 at each corner. I would prefer to find some used stock wheels instead of knockoffs just in case the quality is bad.
I guess I have two questions. First, were Giulias ever sold with the same width in the five hole front to back? Secondly, if I don't want to have a staggered set, can I just run the stock front wheels on the back as well?
I don't have anything against a staggered setup per se, but narrower wheels can be better on snow, this car is a daily so I don't need to have track star grip, I can do without the extra rear width just for gas mileage sake, and ease of tire purchasing and rotation.
Anywho....thanks for any help in advance.
2017 Giulia Ti Sport Q4
You will be fine with the 19x8 on all for corners, or 19x8.5, or 19x9, or 19x8 front and 19x9 rear or whatever you want. If you are a Q4 just make sure tire diameters are similar.
IMO, unless you are going for ULTIMATE performance, stick with a square set-up. One reason, you can rotate them. In the new issue of the Alfa Owner, a fellow is selling four 18x8 OEM new car take-off wheels for $450. Jon Elvert 225-287-4956 I have no affiliation.
The stock rim size for 2021 Ti is 18x8 square. The option is 19x8/19x9 staggered. I plan to run 18x8 square for winter tires.
My 2021 Ti came optioned with 19” square set-up 225/40/R19 tires (19 x 8)
Yes, that is another option. There are a lot of options haha. I just meant for the OP that square is the normal setup.
Reactions: wingler
1 - 8 of 8 Posts
